Pics: 305 or 350?
Discussion in 'The Garage' started by prossett, Sep 30, 2005.
  1. prossett
    prossett 1/2 ton status
    Sep 29, 2005
    165
    United Arab Emirates
    Can anyone tell if this is a 305 or a 350?
    It's from a 1983 GMC Jimmy and the VIN tells me it's a 305, but who knows if it's been swapped out in the past 22 years...
    Any other way of knowing?
  2. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    well I do know in the back of the engine it will give the size... 5.7 or 5.0...etc... but it is behind the distributor.. hard to see when in the truck...
  3. prossett
    Sep 29, 2005
    165
  4. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    i didnt think that they started doing that till 86 when the one piece seal was introduced. (putting the 5.0 or 5.7 on the block)
    whats the last three letters (or just two) stamped on the front of the pass side block (on the deck surface)?
    ryan
  5. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Form looking at the HB it appears to be a 305. I can only see a small cross section of it though.
  6. REDCRO_REDNECK
    REDCRO_REDNECK 1/2 ton status
    Apr 7, 2005
    241
    mo
    I have 2 pre-one piece seal blocks that have the 5.0 LG cast in them one is a 1983 block
  7. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    maybe it was 80 when they moved the dipstick then?
    ryan
  8. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    I know someone will correct me if I'm wrong. The 2 305s I have swapped out both had counterbalanced harmonic balancers, not smooth on the backside like a 350. I tried using the 305 balancer on a 350, and it was not pretty!!!
