**PICS** Gear check after install (and a few hundred miles) Calling Experts
Discussion in 'The Garage' started by jakeslim, Apr 1, 2004.
  1. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    Not sure if you can see well, but this is what gears look like after break in window. Gear oil was dirty and grey, but no metal pieces. Magnet had tiny(tiny)metal flakes but not alot. Do you see(if possible) any problems or does it look ok? Disregard the red grease as I was trying to check pattern and had no stuff to do so.
  2. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    Kinda hard to tell without gear paint to see how the gears mesh /forums/images/graemlins/dunno.gif?
    Bill
  3. jakeslim
    Sep 18, 2002
    2,686
    Napa, CA
    think it would be ok to use something else? say lotion or something? The red grease did not work.
  4. Tweetysuarus
    May 25, 2002
    2,294
    Lynnhood,WA
    Gotta use gear paint so it leaves a trace of the gear pattern.
    Bill
  5. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    I can't tell without the marking compound, but are these arrows showing the depth of the worn part of the ring gear?
  6. jakeslim
    Sep 18, 2002
    2,686
    Napa, CA
    some of the arrows you have are, but its not too deep. I think the depth is ok. I put cover back on(after a bling semi-gloss paint job) and filled up. I think I need to see some examples of what it should look like after a few hundred miles.
