Pics: Is this average or below average articulation?
Discussion in 'The Garage' started by mountainexplorer, Feb 7, 2003.
  1. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    I usually drive through the mud and stuff, and rarely try to flex anything; but today I was goofing around with the '75 Orange Blazer and wound up flexing it about as far as it would go. Is this average or below average flex for a '75 K5 with a 4" lift?
    Another picture of it
    and a view from the back.
    It started to try to pull the top up on the back corner, and my clutch linkage (adjustment rod) came off. I think thats the most it would take.
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Doesn't look to bad, but I would expect the front to stuff a little more, and the back to droop a little more. But that all depends on how hard your springs are and what type of lift, etc. Everything is dependent. Overall I wouldn't call it terrible, but it isn't spectacular either.
  3. mountainexplorer
    Nov 14, 2001
    4,903
    They are just Rancho front springs, rear blocks, RS5000 shocks (off my truck that had a 2.5" lift). On level the rear springs sag some...the fronts seem pretty stiff.
  4. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Stiff springs and short shocks will limit articulation every time. But if you are popping linkages and stuff already then sounds like you have some things to work on and fix before you start looking for more articulation.
  5. mountainexplorer
    Nov 14, 2001
    4,903
    I think thats about max for the Blazer. It also has a 3" body lift...which I'm sure isnt too good for flexing a whole bunch. Oh well, I rarely drive the thing anywhere too twisty.
  6. keith
    keith 1/2 ton status
    1,158
    La Fayette, GA
    [​IMG] [​IMG] These are two shots over the years in various stages. first shot has stock shocks and the second one to I think. Not a flex monster but okay for what I do
  7. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    looks good but i like this set-up /forums/images/graemlins/thumb.gif
  8. bigjbear
    Feb 18, 2000
    13,964
    446
    Marietta GA
    Dich the front swaybar, it makes a huge difference. But if your shocks arn't long enough it won't help (at least untill you break the mounts).
  9. uglychevyZZ4
    uglychevyZZ4 3/4 ton status
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    you wanna get at least another 1/3? then ditch the sway bar, and open up the leaf locks front and rear. /forums/images/graemlins/wink.gif
