!! PICS !! My latest fabrication work....
Discussion in 'Pacific Region' started by Greg72, May 28, 2002.
  1. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    OK, for you "real" fabricators....cut me some slack! /forums/images/icons/laugh.gif
    I'm just starting out so these represent what my limited skills will allow for now.
    Here are some spring perches I built over the weekend for my 14BFF swap.
    http://coloradok5.com/gallery/albur18
    Enjoy!
  2. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    looks slick to me! Is this going in the '72 or the eternal build-up frame monster/forums/images/icons/laugh.gif/forums/images/icons/wink.gif
  3. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Those go on the '72. I've got to get things going for BlazerFest....
    I think I'm going to get a G30 (van) axle for the "spare" frame. Might as well get the proper track width without spacers if I can.
  4. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Look's good Greg.
  5. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    They look good! I made some like that but I didn't angle the bottom...I just left it square...but I guess you wouldn't be able to get them over the axle tube. I added about 1/2" of lift when I made mine. I used a hole saw (not fun!) to cut the hole. I used a 3.5" hole saw and did them both at once to make it easier.
    How are you going to do the spring plates? I left the spring perch symetrical but drilled the center pin holes 1" forward (to move the axle back 1"). Movving your center pin back 2" might move the center pin out from under the u-bolt plate?
  6. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Dan,
    I've ordered the Tuff Country "reversal U-Bolt" kit, so I'll have to take a look at what I end up with once that arrives.......
    Probably some more head-scratching before all is said and done! /forums/images/icons/laugh.gif
    I did go out on my lunch break and buy a nice floorstanding drill press and drillbit set. Now I can at least make "nice" holes in metal.....one step at a time. /forums/images/icons/cool.gif
  7. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    So you have had the bolts that point down?...Those suck.
    I used the stock 3/4-ton u-bolt plates...I had to drill a hole in them where for the end of the center pin. I could have gone maybe 1/2" more but I think that moving it back 1" is the right ammount for my truck.
    By the end of the summer it won't matter anyway...
    I am going to put in the 63" leaves and mount them so the springs will be moved back and the center pin will be at the center line of the axle.
