*PIC'S* of 12 bolt rear disc brake install
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by BobK, Jun 7, 2002.
  1. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    *PIC\'S* of 12 bolt rear disc brake install
    Finally finished my rear disc install on my 71 Blazer.I used the TSM kit.It took me about 2 days(taking my time)and went real smooth.
    I am having trouble getting the air out of the system(see my post-CAN'T GET A HARD PEDAL) so the jury is out on any braking performance improvments as of yet.
    Total cost was roughly $400.00.Prob. could have done it a little cheaper but I went with new parts instead of used ones.
    Click the link to see the pic's.
    http://www.imagestation.com/album/?id=4292219125
  2. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    Re: *PIC\'S* of 12 bolt rear disc brake install
    Nice pics, Bob. Thanks for sharing.
  3. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    looks like you did it the right way.did you replace the carrier bearings also?does the disk slide on the axle and then tighten down when you put the tire back on like if you still had the drum on there?
  4. Steve_Chin
    Mar 6, 2001
    1,126
    The hat of the rotor fits over the axle flange and around the studs, just like the drum does.
    The parking brake in those calipers is marginal with 32" tires. With bigger tires, it's not really what I'd call functional.
  5. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Nope ,just replaced the bearing at the wheel.
