Pics of a 8 lug to 6 lug adapter???
Discussion in 'The Garage' started by 4xcrazy, Feb 12, 2004.
  1. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    Does anybody have any pics of the 8 lug to 6 lug adapter? Or maybe any comments on this product. I am curious as to the quality of this product and if it's worth it to be able to run my stock wheels...
    /forums/images/graemlins/burb.gif /forums/images/graemlins/whistling.gif
  2. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Here is a pic of the adapters that TonyP makes....
  3. crawlink5
    crawlink5 1/2 ton status
    Oct 9, 2003
    431
    Spring, TX
    will the six lug wheel fit over the hub?
  4. 4xcrazy
    Oct 31, 2003
    9,472
    5
    now THATS, a good question, i guess i'll have to go out and measure the center hole.
    Any idea on what these cost?
  5. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
  6. 77ChevyK10
    77ChevyK10 1/2 ton status
    Feb 2, 2003
    317
    Laveen, AZ
    i would like to make some of those
    do you only use 6 of the 8 lugs to hold the spacer on
    Andrew
  7. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    yes the hubs need to be turned down so your 6 lug rim will slide over them, then it's just like adding a 1"inch spacer on the rear axle per side...you do use only 6 of the 8 lug studs... /forums/images/graemlins/thumb.gif
  8. 4xcrazy
    Oct 31, 2003
    9,472
    5
    Kinda like this?
    These are from
    Grady's Extreme Off-Road!
    Bill
    Oh my god those things are nice, but geez, you act like i have a job or somethin?? those things are severly priced!!!
    /forums/images/graemlins/yikes.gif /forums/images/graemlins/yikes.gif /forums/images/graemlins/yikes.gif /forums/images/graemlins/yikes.gif /forums/images/graemlins/yikes.gif /forums/images/graemlins/yikes.gif /forums/images/graemlins/yikes.gif
  9. Tweetysuarus
    May 25, 2002
    2,294
    Lynnhood,WA
    Kinda like this?
    These are from
    Bill
    /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
    Yeah, I know, But there kool for the Bling factor!
    Bill
  10. SlamChops
    SlamChops Newbie
    May 20, 2003
    how much do your adapters cost?
  11. 4xcrazy
    Oct 31, 2003
    9,472
    5
    I was informed they run $165 for the set and then it runs around $75 to have the hubs and axle bolt plates shaved down to accomodate the smaller wheel opening.
    Seriously thinkin about goin this route, tires i have been noticing are alittle cheaper for 15"rims as opposed to the 16's. And i don't really do anything super extreme like rock crawling to where i think i'd be in danger of breaking them. I usually have to take it easy anyways with the "R.V" when wheelin, already broke the 1/2 axle housing wheelin it.
  12. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Hey Tj why don't you just go out side and grab one of your aluminum ralley's and see it it slides over your hub. Some aluminum rims fit I belive. If not then you'll have to turn em'. And go to bed so you can help lift my truck tommorrow /forums/images/graemlins/waytogo.gif
  13. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    have you looked at what the cost difference is to make custom hubs vs those adapters and machine work on the factory hub?
    I cannot see it being that much different in the end to do it right vs the bandaid approach
    oh man Gradies is right by the track, have to check them out next race
  14. 4xcrazy
    Oct 31, 2003
    9,472
    5
    Well thats kinda why i haven't come to a definate decision on it yet, i am still lookin around and the possibility of just converting the front over to 8 lug is still there as i already have the parts. I would need to purchase wheels if i went that route and either way i still need new tires, so the costs of everything, i really don't know yet. With the higher cost of 16" tires, this is another pondering thing as in the long run runnin 15" would be cheaper, but the fact of runnin 8 lug equipment just seems to be the stronger option. Another reason to wait is to see what options and ideas come up on this post, Thanks for the insight though, keep em coming,,, /forums/images/graemlins/waytogo.gif
