Pics of bobbed k5's please...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by reddog64, Jul 3, 2002.
  1. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    Pics of bobbed k5\'s please...
    I have to bob the rear of my k5 due to a little rust problem... does anyone have pics of this...
    PLEASE!!!
  2. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    Re: Pics of bobbed k5\'s please...
    what kinda bob job you going for? just hacking it off and using flat plat like dblazer and others have done, or just bring the stock tail lights and tail gate up to the fender well.??
  3. reddog64
    Nov 9, 2000
    3,325
    i need to lose the rear part from the rear fender well to the back... from the trim level down...
  4. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    Well, me being the gear head, custom fab, too dumb to tell him self NO kinda person. I would try to reinstall the tail gate and stock corner set up as far farword as you can. so a c-channel ( or tube )bumper is right at the spring hangers. then hack the fenderwell so it is flat witht he top part. /forums/images/icons/cool.gif
    It's alot of work, but thats just me.
  5. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    what 55 said looks cool on the toys, but it was too much work and too much weight for me. I kept mine simple and you can see it in my webshots signature if you'd like.
  6. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    check out DBLAZER's pics...do a search on him...his rig is pretty much extremely bobbed and stripped as far as the bed is concerned
    Later
  7. MTPockets
    MTPockets 1/2 ton status
    Feb 19, 2000
    502
    Gainesville, Florida
    like this?
    theres more, just click below...
  8. 8BaLL
    8BaLL Registered Member
    Jun 13, 2002
    64
    Northwest Missouri
    I am planning on cutting out my fenders and bed quite a bit. After you cut up that high did you just leave the metal as is or did you weld the two pieces together to kind of make a nicer edge? I dont know if after I cut mine off real high that I shoud just leave the metal as is or try to some how weld the two pieces of metal back together to make a better edge. Its hard to describe but I hope you kinda know what I'm talkin about /forums/images/icons/confused.gif
  9. DBLAZER
    DBLAZER 1/2 ton status
    Apr 2, 2000
    1,716
    Haslet, Tx
    Maybe this will help.... Finished product
  10. MTPockets
    Feb 19, 2000
    502
    i left the two edges open but the rub rails close that hole up nicely. if i hadn't built the exo-cage then i would have done something similar to what you are thinking about doing.
    on the other hand...what D has done is much simpler, durable, and purposeful.
  11. 8BaLL
    Jun 13, 2002
    64
    Northwest Missouri
    How did you make the rub rails? What are they made of and how did you attatch them?
  12. Thumper
    Thumper 1/2 ton status
    1,582
    Alberta Canada
    Well, I think I have decided to bob my Jimmy. I have a major rust problem, so much so that I am looking at replacing the entire rear section from the wheelwell back to the end of the floor. I also have to get new side pillars, and both cross braces too. My plan is to chop the entire back of the truck straight across much like MTpockets did. Then remove the rearmost section from my donor pickup truck, and weld it on the Jimmy again. Concievably, the rear will resemble a stock Jimmy, but be 12" shorter. I am also ditching the tailgate, and the tire rack/ carrier, in favor of a prerunner mount like UAV. As for the gas tank, the plan so far is to attempt to move the tank forward to where the frame raises up. My reasoning is such... I have to do this much work anyways, and if anytime in the foreseeable future I will ever want to bob it... when better?
    So, should be starting this job in the next week or so. I will be taking lots of pics, so will keep everyone updated. Might have to go for one last wheeling trip with it this Sunday... hmmm
    Mike
  13. reddog64
    Nov 9, 2000
    3,325
    hey mtpockets!!!
    That's exactly what i wanna do to the back.. how did you do it.. what is making that round looking edge???
  14. uglychevyZZ4
    uglychevyZZ4 3/4 ton status
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    do you have a link to see that ord snorkel ????? i been lookin for one thatll bolt to a carb. thnx and oh, nice rig!
