Pics of F250 shock towers
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Shawn, Jun 14, 2000.
  1. Shawn
    Shawn 1/2 ton status Premium Member Author
    1,753
    5
    5280'
    Just got the longer F250 shock towers today for the 9012 Rancho shocks. These things are long! Not to worry since you can cut the bottom off and customize them to fit. The bottom has a slight bend in it which would mean fender well trimming so it should be cut anyway. Now I just need to mount them. If I have any problems, I'll let you guys know.
    Shawn
    87 K5
  2. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    Thanks for that pic! I for one, would like to see a report on how it goes. I'm ordering mine today! Are you running 9012s for the rear also like Depdog?
    [​IMG][​IMG]
    Durant, Ok
    '79 Blazer in progress
  3. Emmettology 101
    May 9, 2000
    8,126
    FL
    What were the part numbers for those?
    And how long should they be cut to?(from very top to very bottom)
    Thanks!
    Mike [​IMG]
    1982 GMC Jimmy - <font color=green>Emmett</font color=green>
    http://emmett.coloradok5.com
  4. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    Shawn,
    What years are those from? I would also like to get price and part number. Thanks.
    Neil
    Mudzer 1978/91 K5
  5. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    Call Parts Mike (530-885-0673), he has them for much cheaper than the Ford dealer. Shawn got his from Parts Mike, for about $15 each!
    ken
  6. Shawn
    1,753
    5
    5280'
    Like Ken said, you can get them from Parts Mike. Ford Part # is E5TZ-18183-A. I'm not sure the exact years but I know a 1980 F250 will work. The funny thing is I just called another Ford dealer to verify the outragous $40 (each) I was quoted last week. The other dealer only wanted $17.30 each so if Parts Mike is out, you could hit the Ford dealer. Just make sure to verify the price first before you go there. I'm not sure how much to cut yet. I'll probably do a write up on off-road.com when I'm finished.
    Shawn
    87 K5
  7. bigdaddy89
    bigdaddy89 1/2 ton status
    May 18, 2000
    422
    Phx, Az
    Do these look like there are able to be modified to work with dual shocks?
  8. Shawn
    1,753
    5
    5280'
    Not sure about the dual shock idea. I imagine you could get 4 of these mounts to do this or modify the single bracket somehow to accept two shocks.
    Shawn
  9. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Either Four Wheeler or 4-Wheel and Off-Road has a lift-kit article this month that shows an aftermarket dual shock mount for Fords. It replaces the single shock mount like the one in Shawn's picture. I can't remember for sure who makes it. Maybe Superlift?
    You really don't need dual shocks unless you're desert racing or like to jump your truck. You'll never overheat one of those 9012's rockcrawlilng or mud bogging.
    http://ThunderTruck.ColoradoK5.com
  10. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    I agree...we have factory dual front shocks on our '90 Sub and I removed one of them on each side. Just don't need to drive around in a brick!!! Dual shocks are pretty much useless unless you're banzai-ing out in the desert at high speeds.
    ken
  11. bigdaddy89
    May 18, 2000
    422
    Phx, Az
    BANZAI! Just kidding.
  12. Shawn
    1,753
    5
    5280'
    I'd have to agree with both Harry and Ken. The front dual shocks just made the K5 ride worse so I took them off. I really laugh at the show trucks running 4 shocks per wheel front and rear!
    Shawn
  13. Corey-88K5
    Corey-88K5 1/2 ton status
    720
    Home: Michigan, Stationed: Hill AFB (Home of Moab.
    Dual shocks are setup to be valved at about 1/2 of what a normal single shock setup would be set at. They are used so that the heavy body will beable to absorbe the bumbs in the shocks and not cause fade over a short period of time.
    Corey
    88K5
    [​IMG]<font color=red>Girls Like Guys In Bow Ties
    http://www.geocities.com/corey_perez
  14. Shawn
    1,753
    5
    5280'
    Tell Procomp that! My old Procomp 3000 shocks were supposely valved for a quad setup for the front but they weren't. With the 9000's, you could adjust them manually to get that setting. Also, having to buy 6 shocks sucks if you're on a tight budget.
    Shawn
  15. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    That's what I had too, the ProComp shocks...4 of em up front (on a 6" Superlift)...rode worse than my 10" Superlifted dually!!! Off came the front 2nd shock per corner!!! Much nicer now!!!
    ken
  16. CK5
    May 19, 1999
    21,623
    701
    CO
    I took off my extra shocks (Rancho 5000) and it rides a lot smoother. It rides like a Fire truck now instead of a lumber wagon. [​IMG] I plan on redoing the entire suspension this winter - I hope!!
    Steve
  17. Corey-88K5
    720
    I currently have 2 Crapo (read rancho) shocks from a quad shock setup on the front of my blazer. THEY SUCK! WHen I stop the nose keeps bobbing up and down. Not to mention the severe nose dive when under braking.
    I'm going quad.
    Corey
    88K5
  18. CK5
    May 19, 1999
    21,623
    701
    CO
    I currently am running the Crapo (read rancho) 4" springs in the front, they are so stiff that I think I could run no shocks at all and I still wouldn't have any nose dive. My ride is so rough (how rough is it?) I used to be 6` 5" tall before I bought it now I am 5`11" tall. badda boom
    I must be getting tired
    Steve
  19. BigBadBowTie
    BigBadBowTie 1/2 ton status
    Apr 6, 2000
    160
    AZ
    Ok, I'm way behind on this issue. Are these mounts bolt on? I will be buying new shocks all the way around in the next two weeks, I f I can buy 4 instead of six I can swing for the RS9000's. Are there any other modifications needed to run those 9012's?
    Rick
    86 K-5
    http://www.BigBadBowTie.ColoradoK5.com
  20. Brady
    Brady 1/2 ton status
    May 6, 2000
    628
    Parachute,Co
    Are you using the stock mount on the axle?Or a custom one?Brady
