Pics of H1 rims-TRE clearance with 1.5" spacers
Discussion in 'The Garage' started by Ronnie4wd, Oct 17, 2006.
  1. Ronnie4wd
    Ronnie4wd 1/2 ton status GMOTM Winner
    Jun 4, 2002
    749
    Stockholm.Sweden
  2. muddermilitia
    muddermilitia ThatTrazerGuy GMOTM Winner
    Nov 10, 2005
    5,742
    76
    NE Illinois
    Im thinking about H1s for my truck, how much did those spacers set you back? And do you also have 1.5s on the back?
  3. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    so those are stock h1's? they clear!
  4. Ronnie4wd
    Jun 4, 2002
    749
    Stockholm.Sweden
    Yes they clear,with my 1.5" spacers that I have on all four wheels.
    If you want a wide truck get the rims recentered instead ;)
    I like my truck slim so I can go where the samis and heeps go:wink1:
  5. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    A 1.5" spacer would give them the same BS as a H2 wheel, right?
  6. muddermilitia
    Nov 10, 2005
    5,742
    76
    NE Illinois
    LOL I hear ya!
  7. Ronnie4wd
    Jun 4, 2002
    749
    Stockholm.Sweden
    I guess the BS on the H1 is 7" so it would be 5.5" with the spacer.
    I don´t know the BS of a H2 wheel
  8. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    Looks good but my question is are your tires hitting the steering box or springs at full lock?
  9. Ronnie4wd
    Jun 4, 2002
    749
    Stockholm.Sweden
    No just the front end of the draglink as you can see in the first pics.
  10. cbbr
    Jul 17, 2004
    14,681
    Yep. I think that H2's are 5.5.
  11. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    How close is the tire to the inner wheel well in the rear?
    This makes me want my HMMWV rims on even more. Thanks for the pics.
  12. Ronnie4wd
    Jun 4, 2002
    749
    Stockholm.Sweden
    When flexing (as much as it can with 1-ton rear springs and 6" blocks)it touches the wheelwell but no tire damage yet.
    I have been wheeling like this for a couple of years.
    I noticed when I measured my K-5 79 that the wheelwells are a little wider on the K-5s than the pickups :dunno:
    Sorry that can be misunderstood the wheelwells on my K-5 was wider apart from eachother than they are on my M1008 so I´m not sure that 1.5" spacers in the rear would do the trick on the K-5.
  13. readymix
    May 30, 2004
    6,706
    26
    How far do your front hubs stick out past the rim?
  14. Ronnie4wd
    Jun 4, 2002
    749
    Stockholm.Sweden
    I don´t know :o but will measure til tomorrow and post up :laugh: .
  15. readymix
    May 30, 2004
    6,706
    26
    Cool. I am really considering running the 2" spacers on mine, but when I look at the truck it does not look like it will work........even though you are proof that it will.
  16. Ronnie4wd
    Jun 4, 2002
    749
    Stockholm.Sweden
    From the outside of the lockinghub to where the rim is widest (on the lip just outside the bead) it´s 1,5" or 40mm.
    If I measure from the tire outside to the hub it´s 0,5" or 13mm that is with 15 38.5 16.5 boggers
  17. readymix
    May 30, 2004
    6,706
    26
    :haha: Well I guess my eyes are just not calibrated then:haha:
    Everytime I look at my axles it seems like the design of the rims just will not work even with the 2" spacers. I will measure again then try to talk my wife into letting me buy some spacers.
  18. blazin_blazer
    blazin_blazer 1/2 ton status
    Aug 2, 2005
    4,043
    central arkansas
    so if i use a 2" spacer and h2 rims it would be the same as a 3.5" bs? summit told me their eaton steel truck wheels only come with 3.5" bs. where do you get 2" spacers? 1.5 is the thickest i've ever seen.
  19. readymix
    May 30, 2004
    6,706
    26
    look in the vendor forum
  20. blazin83
    blazin83 Registered Member
    Mar 6, 2006
    18
    atlanta Ga
    i wonder how that would work in the back.. that front end is a good bit wider than the back.. it looks goofy from behind.
