pics of inboarded rear springs?
Discussion in 'The Garage' started by outlaw612, Dec 13, 2003.
  1. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    Does anyone have any pics of inboarded springs? Im thinking of doing this and need some ideas. Im wanting to get no more than 3" of lift over stock.
  2. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Your pretty much forced in to 4" minimum of lift unless you really shorten your shackle. When you slide the springs inboard under the frame you have to flip the shackle. Unless you are talking about going further inboard than that. I don't think I would do that though.
  3. outlaw612
    Feb 11, 2001
    2,342
    Thats what Im afraid of. Im gonna try to find some way to do it even if it requires major mods to the rear of the frame. Im needing pics for ideas and to figure out how I want to attach the hangers.
  4. LlanoK5
    LlanoK5 1/2 ton status
    May 26, 2002
    202
    Llano, Tx
    I've got a few picks, I'll try to post one /forums/images/graemlins/rolleyes.gif. If not there should be some in link in my sig.
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    in boarded, hummmmmm....! pretty interesting, i want pics too and how to do this one !
  6. outlaw612
    Feb 11, 2001
    2,342
    One guy gave me the idea of using a setup like on the rear of the front spring. I think I might be able to get dowm to 2-3" by going this route. I have 2 concerns though:
    1) Is there any reasons not to use this setup in the rear?
    2) Getting this close to the frame is gonna limit compression, will it negate the whole idea of inboarding for more flex?
  7. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    [/ QUOTE ] The one in your pictures is pretty much what I am doing, I am going to run 63s and no scissor shackle though.
  8. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    PM blazinzuk. He has done this with some Dodge springs and ended up with a shitload of flex.
  9. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    LlanoK5
    That's sexier than a monkey in a spandex jump suit! TruckNutsDude
    Does this mean I'm famous? /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif
  10. ducttape114
    ducttape114 1/2 ton status
    Aug 1, 2002
    990
    Orcutt Ca
    i will try to find some pics of mine. the way i did it you can pretty much choose any ride hidth you want. it is extremly goofy looking though.
  11. ducttape114
    Aug 1, 2002
    990
    Orcutt Ca
    ok here we go you can kind of see it in these ones. [​IMG]
    the front hanger is two peices of 1/2" plate thru bolted on either side of the frame. the frame is boxed for 18" with 3/16" plate. theres a spacer on either side of the frame, inside the hangers to hold the spring in the proper positon. in the rear the shackles are 13.5 eye to eye. they are mounted to the top of the frame with a 3.5" bushing. the lower end of the shackel has a 1/2' spacer to hold the spring in the proper position. the springs are 63s with one leaf removed off a 97 half ton. all together it only cost about $200. lots of time thou. i could have done it cheaper but i did a lot of experimenting before it figured out how to do it "right". hope this helps.
  12. outlaw612
    Feb 11, 2001
    2,342
    I cant see them, just red x's /forums/images/graemlins/frown.gif
  13. SF87K5
    SF87K5 1/2 ton status
    Oct 27, 2002
    1,105
    Stedman, North Carolina
    Outlaw, just right click on the red x and goto the properties and copy the url and then past in your address box and hit enter.
    Webshots do not allow you to post pics for somereason. I hope this helps you to see the pics. /forums/images/graemlins/thumb.gif
  14. outlaw612
    Feb 11, 2001
    2,342
    I tried, it wont work.
  15. outlaw612
    Feb 11, 2001
    2,342
    I tried, it wont work. /forums/images/graemlins/confused.gif
  16. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
  17. outlaw612
    Feb 11, 2001
    2,342
    Forbidden
    You don't have permission to access /s/image2/5/88/48/94258848ABXEGG_ph.jpg on this server.
    Apache/1.3.27 Server at community.webshots.com Port 80
  18. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    right click - copy shortcut - paste in address bar - works just fine
  19. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    If I wanted to stay with less than 4" lift and not shorten shackles I guess what I would do here is Go ahead and flip the shackle. Keep it the same as factory length and stick a bushing through the frame just kissing the bottom of the frame rail. This should keep the amount of lift at a minimum and still retain as much flex as possible. This is how I intended on doing mine until I decided on a 3/4 eliptic setup with the springs inboarded.
  20. outlaw612
    Feb 11, 2001
    2,342
    Thats about what Im thinking Ill try. Thanks for the pics guys, keep them coming! /forums/images/graemlins/thumb.gif
