Pics of jerry can holder on rear bumper
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by CK5, Oct 11, 2000.
  1. CK5
    May 19, 1999
    21,627
    704
    CO
    I think someone was asking about how I mounted jerry cans to my rear bumper, I bought a metal 2-can carrier from americanvan.com and welded (OK Tim welded it) it to my bumper sitting on top of 2" angle to form a base. I also cut the frame 3" to tuck the bumper in real close, I also have enough room for a 38" tire on the carrier that is why it isn't in closer. oh yeah, and the tire mount is raked back 10 degrees for a closer fit.
    5,000 Pounds of American Rolling Steel
  2. smp
    smp 1/2 ton status
    Jul 5, 2000
    708
    Florida
    i like how you put your licence plate on there to, looks sweet steve. but how do you put your tailgate down?
    <font color=red>SMP</font color=red>
  3. CK5
    May 19, 1999
    21,627
    704
    CO
    The part that has the jerry cans and tire swings out to the side, then you put the tail gate down.
  4. JunkYardCrawler
    JunkYardCrawler 1/2 ton status
    Sep 9, 2000
    575
    Tucson, AZ
    looks good. But man u have a really clean garage
    Well as it gose it gose and under it rolls heavey rubber bouncing on a head.
    (hey i'm a poet)
  5. rich'90
    rich'90 1/2 ton status
    Feb 27, 2000
    159
    Savannah, GA
    The holder looks great. Much better and more sturdy than the chincy little thing KMA puts on. Did you take off the D-rings?
    go heavy or go home
  6. CK5
    May 19, 1999
    21,627
    704
    CO
    I have the shackle mounts now that allow you to remove the shackles when not in use.
  7. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    A few questions as I'm currently designing a bumper. Did you run the D ring mounts thru the bumper or just butt them up and weld them? How did you do your latch and hinge? Any possibility of closer pics of that? I love the 2 can holder, might have to research amerivan. Oh yeah one more, what size tubing is the main bumper? I'm using 3x5x1/4 Thanks.
    Bryan
    [​IMG][​IMG]
    Durant, Ok
    '79 Blaze- 350/350/203, 14B w/detroit, D44, 4.11s, 4" susp, 36" TSL
  8. CK5
    May 19, 1999
    21,627
    704
    CO
    I believe the shackle mounts are butted up and welded, the latch works with a pin surrounded by a spring that fits into a hole in the bumper, it also has a small plate in the shape of a C that keeps it from coming out. I might have to draw you a pic, because pics of a black bumper don't always come out that good. The main bumper is 3x5 - 3/16".
  9. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
  10. blazen91
    blazen91 1/2 ton status
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    Thank you, Steve for posting this. I was the person who requested the pics and am hoping to get a scanner soon so I can post the bumper/tire carrier I built.C-ya.
    blazen91
  11. laketex
    6,220
    North Texas
    Great, I don't think I'll need the drawing but someone else might. We actually use something very similar at work for outrigger pins. I do have a question about your hinges though. Do they have bushings and did you make them or are they an order only part? Do you have any idea where to get these? And does your bumper sag at all when it's unpinned and swung away. I guess do you have to lift it up when you swing it back into place?
    Thanks, if you couldn't tell I really like your design and some points are a lot better than my own. I was flipping back and forth on the hinge thing. One pipe inside another was a first thought, but it would be really difficult to obtain the tight tolerance needed to prevent sag and not have it lock up over time.
    On another note, I see that americanvan.com has a 3 jerry can holder as well as the two but no pic. Do you know offhand if that one puts them all side by side? I thought of using 2 for fuel and then painting the third a different color and using it for water. Good idea or not?
    Thanks for any input you can give. It's all appreciated greatly.
    Bryan
    [​IMG][​IMG]
    Durant, Ok
  12. CK5
    May 19, 1999
    21,627
    704
    CO
    Currently, the swing arm has a 1" bolt that fits into a 1" ID pipe that is in the bumper, I may go to a bearing assembly (I think www.rockstomper.com has these) in the future, one pro to the bolt is that I can take the swing arm off for trips to Moab where I need extreme departure angles, I just throw the spare in the back. It sags just a little, I have to lift it up about a 1/4" is all. You would have to call americanvan.com about the 3 can carrier, my guess is that it is 3 in a row. I think 2 cans, one for gas and one with a water/antifreeze mixture would be fine, 2 is pushing the weight issue as it is.
  13. laketex
    6,220
    North Texas
    Thanks Steve
    [​IMG][​IMG]
    Durant, Ok
