**PICS** of my brackets/ram installation
Discussion in 'The Garage' started by Poohbair, Jan 9, 2005.
  1. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    With the tierod above and behind the axle I had to decide what to do to get the ram mounted for the hydro assist. I decided to make a bracket and go that route. Took me all day, but I got it done and all bolted together tonight. I built 3 of them before I got one I liked. This one wraps around the axle and is welded on, with a side brace... and it bolts to the side of the spring plate as well where the old sway bar used to go (has about a 2" spacer in there) Here are a few pics.
    Look mom, nothing to bank around in the rocks!!!!
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    pretty crafty
  3. jekbrown
    May 19, 2001
    45,030
    364
    Vancouver, WA, USA
    looks good. Im gonna have to do the same thing when I relocate my tie rod. I am already running the WFO arms... just waiting for the 52" spring swap and shock relocation before I get to the hydro. Anway, good job! :)
    j
  4. white-rhyno
    white-rhyno 1/2 ton status
    Jan 27, 2002
    942
    Ellensburg Washington
    Wow, i have seen some interesting stuff pulled from your A$$ before but that looks decent, so really, who did you buy that from?
    J/J looks good man.
  5. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    yall arnt having trouble with the tierod hitting the springs with the 52's??
  6. white-rhyno
    Jan 27, 2002
    942
    not if its done right
  7. Poohbair
    Jan 30, 2003
    2,139
    Ellensburg, WA
    My 52's have the overload removed and replaced w/ a thin leaf from a set of Skyjacker springs, and then a THIN 0 rate/shim. I have about an inch or more of clearance between the spring and the tierod. Before I messed w/ the spring pack and had a regular add a leaf in I did have issues.
  8. Poohbair
    Jan 30, 2003
    2,139
    Ellensburg, WA
    Yeah, I have made some pretty shady stuff in the (not so distant) past...:grin:
  9. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    Is the 1" of clearance with it flexed??
  10. Poohbair
    Jan 30, 2003
    2,139
    Ellensburg, WA
    Nope. It gets less, but from what I can make it flex sitting in the shop I can't make it touch now. I will find out in a few weeks when I get this thing out of the shop FINALLY! It has only been about 6 months...:crazy:
  11. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    Cool keep us posted, man 6 months I bet you are excited :)
  12. tRustyK5
    Jul 23, 2000
    36,170
    1,377
    E-town baby!
    In the second pic with the piece installed I can see a future problem for you. I'm not trying to be an ass, but I think your bracket is gonna bend where it meets the spring plate. I would add a gusset on the backside to the spring plate. A piece of tubing would be ideal, and you wouldn't need to weld the gusset to the spring plate either...under pressure it'll jam into the spring plate and stop it from bending.
    Without the gusset if you get into some big rocks the plate could bend before the tires move (if they're up against a big rock)
    Rene
  13. Poohbair
    Jan 30, 2003
    2,139
    Ellensburg, WA
    Thanks for the suggestion. I thought about that when I built it, but then after more contemplating I think it will be ok. The bottom ram mount is only about 3/8 of an inch above the bolt, and the plate is 3/8". That means that the ram would have to push hard enough to basically bend 3/8" plate RIGHT at the top of the bolt.
    It may bend, we will see... but I look at it one way, I have never been afraid of breaking parts on my rig so let 'er fly and see what happens!:grin:
  14. tRustyK5
    Jul 23, 2000
    36,170
    1,377
    E-town baby!
    LOL...
    Just a suggestion.
    Rene
  15. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    yeah you might want to get some longer u bolts too:D
    nice set up, he he he yur axles neekid
  16. Poohbair
    Jan 30, 2003
    2,139
    Ellensburg, WA
    Yeah, I had those made at the spring shop and I have had the frontend in and out so many times that I didn't want to trim them down until I make sure that I have everything where it needs to be.
    :grin: I knew that somebody would mention the Ubolts!! I can't believe it wasn't in the 1st 3 or 4 replys!!:grin:
  17. ramjet gmc
    ramjet gmc CK5 Staff Staff Member Moderator GMOTM Winner
    Dec 19, 2001
    3,370
    Milltown NJ 08850 NJ sucks
    that look like a hot set up you will need to get to the mall and test that new ram :grin:
  18. seattlek5
    seattlek5 1/2 ton status
    Feb 23, 2001
    311
    ...with one hand on the bender.
    Are you going full-hydro?
    ....cause I don't see a drag-link in any of those pictures:D
  19. Poohbair
    Jan 30, 2003
    2,139
    Ellensburg, WA
    LOL... :grin: You sum' bish!! ...at least one of us got to use it! I will either get it back from you or you can just get me a different one... whatever you want to do.
  20. seattlek5
    Feb 23, 2001
    311
    shouldn't you be working or something:D I'll just give you your stuff back, don't know when I'll get around to putting mine back together (...a week before Memorial Day most likely.)
