Pics of my DP-Built Winch Bumper *UPDATED WITH PICS OF FINISHED BUMPER*
Discussion in 'The Garage' started by DPI, May 21, 2002.
  1. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    I just installed my new tube bumper I built, just need to add the D-ring recover points and the winch cable and it will be done. <a target="_blank" href=http://coloradok5.com/gallery/Front-Bumper>Here</a> are some pics. The winch is a Ramsey RE12000R and is mounted as close to the frame/body as this style of winch would allow. The actual winch mount is fabbed from 5/8" plate steel and three different sizes of schedule 80 tubing was used for the bumper. The bumper weighs 155 lbs dry and 255 lbs with the loaded winch.
    I have to give some credit to BigJ. His bumper design was the inspiration to build mine. His bumper design is awesome and I loved the look. Thanks BigJ !
  2. Re: Pics of my DP-Built Winch Bumper
    That bumper is sweet - looks like a lot of work paid off for you. What was the rough cost of materials?
  3. ramjet gmc
    ramjet gmc CK5 Staff Staff Member Moderator GMOTM Winner
    Dec 19, 2001
    3,370
    Milltown NJ 08850 NJ sucks
    That looks great and looks good on your truck to /forums/images/icons/smile.gif
  4. Grim-Reaper
    7,385
    Atlanta
    Nice! /forums/images/icons/cool.gif What bender did you use?
  5. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    Thanks.
    I used the $69 special from <a target="_blank" href=http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=32888>Harbor Freight</a>. Worked pretty good, it helped to fill the tube with sand before I would make each bend.
  6. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    Thanks, yeah I spent probably 20 hours building it, but I feel the outcome was worth it.
    The cost of the materials actually ending up in the bumper was about $75 bucks including mounting hardware. I spent twice that much bending tube and going through the trial and error thing. Lots of complex angles to deal with when making the bends. I will be starting on the rear bumper next. My wife loved to hear that./forums/images/icons/shocked.gif
  7. BIGJ
    BIGJ 1/2 ton status Author
    896
    Central Arkansas
    Looks good. Glad to see some different looks on the tube design. I'd like to see some better pics of the winch box if you've got em'.
    I wasted a little tube too on the first one I built. Multiple bends and notches can be pretty tricky.
    BIGJ
  8. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    Thanks Oh great one ! /forums/images/icons/cool.gif
    I will get some more pictures tonight of the mounting setup.
  9. Mreetz
    Mreetz 1/2 ton status
    Jun 26, 2001
    1,282
    Subs of Denver, Colorado
    So that harbor freight bender was able to handle this? Which one did you get? I was going to get one and people told me to avoid it......
    Thanks,
    Marty----
  10. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Looks good ,what did you notch the ends of the pipe with?Iv just been clamping the pieces in my mill and using a hole saw.
  11. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    <a target="_blank" href=http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=32888>THIS</a> is the one I bought.
    It handled it with no problems. It is rated at 12 tons and I placed the "rollers" at the furthest adjustment to use the leverage. So far I have made this bumper and my rock sliders with no problems whatsoever.
  12. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    Yeah, that has been one of the fun and time consuming issues. I basically used my chop saw to make the cut as close as possible and then an angle grinder to make the notches.
  13. BIGJ
    896
    Central Arkansas
    Not hardly a "great one" more like a little guy trying to get a small piece of the pie /forums/images/icons/wink.gif
    A tubing notcher would make your life a lot better as far as time goes. I tried the chop saw method and you are right, it wastes a LOT of time. Plasma cutters work really good for the wide notches.
    BIGJ
  14. FRIZZLEFRY
    Apr 20, 2001
    3,271
    134
    Clovis CA
    I was just wondering cuz I got some funky angles that I cant do like I have been.Im thinking I might have to just notch them with my grinder.Lucky for me Iv only got 2 of those angles to do /forums/images/icons/smile.gif
  15. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    Man, I would love to get a plasma cutter, but I could not force myself to spend a couple grand for a good Lincoln. What kind do you use?
  16. BIGJ
    896
    Central Arkansas
    Buddy of mine has an old miller. I gotta sell some bumpers to get a plasma of my own. The miller works great, but I use the JD2 notcher for just about all of the notches, then round out the rest of the notch with a grinder or the plasma. A torch will work too, just makes a bigger mess. I had a Harbor Freight notcher, it was a total piece of crap. It couldn't make it through two front bumpers.
    BIGJ
  17. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    Good job man! Those things look great! Where did you pick up the winch, and how much did you spend on it?
    -Dan
  18. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    Thanks!
    I got the winch from Sam's Offroad here in Tulsa. A friend and myself went in and bought two at once so they sold them to us for $900 each. Not bad since I see them listed most places for $1095. Also, K5BLT4FUN graciously gave up his door prize from the Disney "Midwest Spring K5 Thing". A gift certificate for $100 rebate on the purchase of a new Ramsey winch.
  19. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    Looks Sweet!! Now all you need to do is cut your fender the same height as your bumper and it will look awesome./forums/images/icons/cool.gif
  20. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    Thanks. Yeah, I know I need to cut the fenders. I am just hesitant to do the first cut... But it is next on the list.
