Pics of my new winch bumper
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by DPI, May 21, 2002.
  1. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    Actually <a target="_blank" href=http://coloradok5.com/forums/showflat.php?Cat=&amp;Board=garage&amp;Number=415385&amp;page=0&amp;view=collapsed&amp;sb=5&amp;o=0&amp;fpart=>Here</a> is the link to "the garage" forum. Just wanted to share with you guys that don't get over there much.
  2. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Saw it on the garage forum...nice rig /forums/images/icons/smile.gif
  3. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Lookw great!
  4. Mudfreak
    Mudfreak 1/2 ton status
    Dec 16, 2000
    116
    NY
    Looks totally awsome DP, can't wait to get mine back together.You're truck is total inspiration!! keep up the good work.
  5. FireBlazer
    FireBlazer Registered Member
    Apr 27, 2002
    10
    Milpitas, CA
    The truck looks great and very good pictures. The pictures brought up a question, I noticed in one of the pictures that you didn't drop the transfer case, I was wondering how you got around that?
  6. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    Nick,
    I tried to drop my case and for some reason my motor mounts would bind up in reverse. I am running a fixed yoke (SYE) on my 241 and a rear CV shaft. With that you do not need to lower the case, which reduces ground clearence. In a couple of the pics in my link below, you can see I tilted the crossmember where the front is a little lower than the rear. This helps make some room for the 1 ton front CV shaft when in full suspension droop.
    Later,
    DP
