Pics of my rock sliders and anti-wrap bar
Discussion in 'The Garage' started by big pappa b, Apr 30, 2005.
  1. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Forgive the dirt but I didn't take pics til after the Tellico run. I did try to hose it off though :p:
    The sliders are 3x3 square tubing with the ends capped. Made the nerf bar part from 1.75" .120 wall. These are welded right to the rocler panel on the top and bottom. There is ZERO movement.
    The anti-wrap bar is similar to the Sam's offroad deisgn. I had "cybrfire" make the axle brackets for me. The tubing for these is 1.75" .219 wall, 1/8" plate is the gusset in the middle. The rear has spring bushings and the front is attached to a large Rubicon express joint. the front mount is welded to the frame on both side and also serves as a place to mount the muffler bracket. I have maybe $80-90 into it. With the 57" springs I did lose about 1" of droop on the passenger side but no binding or loack of droop or stuff on the driver side
  2. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
    Looks good :waytogo:
    It looks like they are welded to the body metal...
    What kind of supports do you have under for structural strength
    "pics , cough , pics" :whistle:
  3. big pappa b
    Jan 3, 2003
    6,328
    Falcon, Colorado
    There are no supports under it. It's welded right there on top along the roclers as well as underneath to the lower parts of the rocker, fender and about 6" of bed.
  4. big jimmy 91
    Feb 21, 2004
    639
    Ok , I see...
    How do you think it will stand up to a severe hit , straight up or sidways , I mean into something solid like a big rock or stump??
    I'm just curious because I have to do the same thing at some point to my own rusty junk lol.
  5. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    You should add on some more support to the sliders if you plan on using them alot. Tie them into the body supports or the body near the frame.
    With the kicker tube on the rockers it will act like a lever every time you land on them trying to pry them away from the body. If you didn't have the kicker tube it wouldn't be as bad but dropping on the kickers is quite common and is the hardest on the sliders.
    Looks good though. I like the setup. It good to see that you went with a good size kicker tube. Mine are 1" .120 wall and they bend if I hit them in an unsupported are. I have had to take the sledge hammer to the kicker tubes to get the doors to go back on after wheeling trips. That is no fun.
    Harley
  6. big pappa b
    Jan 3, 2003
    6,328
    Falcon, Colorado
    I may eventually add something underneath. My friends truck has them mounted the same way. he has abused them thoroughly with no signs of moving or bending. I don't go balls to the wall when out wheeling so they should be just fine like this for a while....if not you can say "I told you so" ;)
  7. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Good looking stuff!!! Ya had to get in a hurry and still came out looking/functioning great! :waytogo:
  8. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    Looks great Bryan! :grin:
  9. Stomper
    Stomper ΜΟΛΩΝ ΛΑΒΕ GMOTM Winner
    May 11, 2002
    3,767
    Iowa
    Sliders look good :waytogo: I did the same only with 3x4 tube with capped 45* angle on both ends. No nerf bars on mine tho. And the anti-wrap bar is pretty much what I'm going to make also....Is the Rubicon joint like a large Heim or somthing else?
    I made my own joint using a hub with tapered roller bearing on an axle shaft.(made the hub and shaft)
  10. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    its a cartridge joint... like a johnny joint but with a few differences. Same concept. I have two of them on the way from when I won that drawing... I ain't going links anytime soon, so I'll prolly end up using them for an anti-wrap bar.
    j
