Pics of my van tilt column installed
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Yukon Jack, Oct 2, 2006.
  1. Yukon Jack
    Yukon Jack 1/2 ton status
    Jul 25, 2002
    1,984
    Rose Hill, KS
    Finally remembered to take some pics of my tilt column that I installed a month or so ago. This is a mid 70's automatic van tilt column that I modified for my manual 4 speed truck. That involved shaving off the tilt shifter attachment point and removing the shift indicator housing and filling in both areas.
    Not sure about the steering wheel - might change that to something different at some point.
  2. 70jimmy
    70jimmy 3/4 ton status Premium Member GMOTM Winner
    Mar 3, 2000
    5,962
    252
    Released from Pueblo, told I belong in Southpark
    Nice been thinking about that swap for the jimmy. I would be interested in seeing a write up about it!!
  3. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    2nd that write-up suggestion. How did you do it?
  4. Yukon Jack
    Jul 25, 2002
    1,984
    Rose Hill, KS
    Here are some pics of the modification process.
    I cut a beer can up to fill in the various holes and used JB weld to secure them and fill in the areas.
    Then ground it smooth.
  5. scasey28
    scasey28 1/2 ton status
    Aug 22, 2005
    105
    chico
    Simply amazing!!!
  6. vtblazer
    vtblazer 1/2 ton status GMOTM Winner
    Sep 30, 2003
    2,471
    Central VT
    Nice work.
    It looks stock. :bow:
    (okay, 'cept for the steering wheel but I like that too)
  7. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    Nice work YJ.
  8. bigblock72
    bigblock72 1/2 ton status Premium Member GMOTM Winner
    Oct 18, 2005
    1,235
    59
    American Fork, Utah
    Looks pretty darn good, doesn't even look that difficult to do, might have to dig a column out of the shed for the Blaze.......
  9. CDA 455
    CDA 455 3/4 ton status
    Jun 2, 2006
    8,598
    43rd State
    Pretty nice work!!
  10. Yukon Jack
    Jul 25, 2002
    1,984
    Rose Hill, KS
    Thanks for the compliments! It is an easy swap. One thing to keep in mind is the van columns are longer so often times you need to shorten your steering shaft by knocking out the nylon pins in the shaft which then allows the shaft to collapse some.
