Pics of rear bumper
Discussion in 'The Garage' started by blzr83, May 3, 2002.
  1. blzr83
    blzr83 Registered Member
    May 11, 2000
    72
    eugene OR
    Hey everyone. I keep seeing pics of tube bumpers popping up so I figured I'd show you guys what I had going. I recently finished the tail light protection so I'm almost done with it! It's pretty much the same design that a lot of the other K5s are using, guess that means it works! I built the main bumper (minus tail light protection) about a year ago....let me know what you think.
    http://coloradok5.com/gallery/albup06
  2. Mreetz
    Mreetz 1/2 ton status
    Jun 26, 2001
    1,282
    Subs of Denver, Colorado
    Looks pretty good!
  3. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    Nice. I like the simplicity and durability.
  4. Depdog
    Depdog 1/2 ton status Author
    1,657
    Georgia
    Yep, looks good, I have been toying with the idea on building some tube bumpers, maybe to sell if I can make a good design. I have a good tube bender now and have a couple of questions for you. What diameter tube did you use? Also do you have any close shots of your mounts and or where your shackels hook up. I have some good desigins for bumepers in my head, both front and rear, but have not given alot of thought to the mounting points to the frame. I want to make the bumper mounting points and the shackle mounting points one in the same.
    Depdog
  5. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    Do the side members have a beam that leads back to the frame? Or how did you support the ears on your bumper?
    Here is how mine is supported:
    <a target="_blank" href=http://community.webshots.com/photo/35650184/35722420ngSZjp>REAR BUMPER BRACE</a>
    -Dan
  6. blzr83
    May 11, 2000
    72
    eugene OR
    I used 1 3/4" 120 and 1 1/2" 120 for the tube and 1/4" plate to mount it to the frame. I will try and get some more detailed shots of mounting points for you. I'm in the process of running a brace from each side of the bumper to the frame much like Steve's and Dan's because the sides do flex enough where they could cause more damage than they would prevent! I'll try and get some better pics with the details soon.
