Pics of Rebuilt Tire Carrier Mount
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Depdog, Oct 9, 2000.
  1. Depdog
    Depdog 1/2 ton status Author
    1,657
    Georgia
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    What did you use in the hinge, bearings or is that a bushing I see?
    i have mine dont similar. I have two plates coming off my bumper and then a square tube going in with a hole drilled the smae size as he bolt and then bolted togther with washers. The bad this now is that the hole in the square tubing is wearing and i was going to weld on a piece of round tubing and use two bearings and washers, then bolt it back together.
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; http://emmett.coloradok5.com
  3. Depdog
    1,657
    Georgia
    The top one off the body is a set of bushings for the front frame eye of the front shackle. The bottom is a stub axle shaft for a trailer with a pair of greased tapered bearings (like front wheel bearings). I had some pipe that I turned down inside for the bearing races to set into.
    Depdog
    <font color=blue>"Lead, Follow, or BECOME the Trail"</font color=blue>
    http://depdogsk5.coloradok5.com
  4. Emmettology 101
    May 9, 2000
    8,126
    FL
