Pics of Rhino Lined interior!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Derf00, Mar 12, 2002.
  1. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    Just posted some pics of the Jimmy just after we got it back from being Rhino Lined. The Rhino Lining is thick enough to give great sound deading and really tightened everything up and quieted a lot of rattles.
    <a target="_blank" href=http://coloradok5.com/gallery/albup66>http://coloradok5.com/gallery/albup66</a>
  2. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    WOW! Looks great Derf!!!!!! Makes me kinda frown on my herculined interior now... Damn you LOL /forums/images/icons/laugh.gif /forums/images/icons/tongue.gif
  3. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    what was the cost?
  4. Bone85K5
    Bone85K5 1/2 ton status
    May 7, 2000
    436
    Columbus, Georgia
    Sweeeeeeeet. I love it. Do u run a hard top? Wonder if you could rhionn-line the underside of a hardtop?
  5. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    That looks pretty sweet, i geuss if you got it dirty you could hose it out
  6. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    yea you can rhino line the inside of a hard top. it is something I'm going to be doing on both my k5's for sound insulation &amp; looks.
  7. Derf00
    Jul 25, 2000
    1,683
    Abilene, TX
    The cost was $400, but the Rhino dealer is a good friend and said it was way to cheap for all the work it took. I also had the top of the bed rails done where the hard top sits. We run without the hard top enough to make this a nice addition over carpet. Now I just need to deal with the wiring and side panels.
  8. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    cheap? 400? i was quoted 350 for that much for rhino lining, but i ended up hurculining it, and im please, but it dont look as nice as
  9. Derf00
    Jul 25, 2000
    1,683
    Abilene, TX
    Prices vary drastically. I have heard of others who said they had quotes in the $6-$700 range. There is only one place here in town that does this. It was cheaper than an over the rail p/u bed. What ever the case I am happy with it.
  10. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    my local bodyshop makes nothing off materials, just his time. he's quoted me $50 per gallon of speedliner, and just his time in labor spraying it. he'll let me do the masking etc. so it should cost around $450 including 6 gallons of liner.
    I'm having entire inside (I have the scottsdale k5) so I'll be doing roof, sides, inside toppers, new panels on the sides, inside fender wells, and floor. (oh yea, bottum of dash &amp; doors etc.)
  11. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    Lookin' Good man!!
    Boss
  12. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Looking great Fred. That roll bar a factory unit?
  13. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    Looks great! I have a question, I have many small little screw holes all over in the floor of mine, and I was wondering if you welded them shut, ot put the liner right over them? The largest hole is about 1/8" dia. I'll probably weld them and grind them flush, but ya never know, I could get lazy.....
  14. Derf00
    Jul 25, 2000
    1,683
    Abilene, TX
    Frank, the roll bar is a Smitty Built.
    Shane, I also had numerous small screw holes that I ground flush, but did not fill. The lining filled the holes and came out smooth. Look at the pic of the side, there were numerous holes for the side panel brackest.
  15. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    Hey Fred,
    Sorry a little off topic, but do you have any more pictures of your fender trimming?
    BTW, nice job on the lining !
  16. shane74
    Feb 12, 2002
    4,100
    Vancouver, WA
    Thanks! I just put in a call to the local Rhino liner shop. They told me it would be $500 to do the whole inside of my truck. Not too bad. They also told me that they have done the exterior of many blazer tops. Anyone had that done? If so, how does it look?
  17. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Looks good. I am still undecided on what I am going to do on mine. I guess it depends on what I find when I gut the interior in a few weeks. If I line it I will do it myself and buy the liner and the gun to spray it at the local body supply place.
  18. johnnyK5
    johnnyK5 Registered Member
    Oct 5, 2001
    95
    Washington, PA
    Did you have your transmission / transfer case floor panel lined seperately? It looks like it wasn't. What if you need to remove it? Did you thread anything into your seat mount holes prior to spraying? I am planning on having this done soon.
  19. Derf00
    Jul 25, 2000
    1,683
    Abilene, TX
    In the unlikley or unfortunate event that the cover ever had to be removed, the lining could easily be cut. Other than seat bolts I did not want any other seams or holes in the floorboard, and that particular seam was a source of some water getting under the mat and carpet. The bolt holes had rolled masking tape inserted in them.
  20. Bullet
    Bullet 1/2 ton status
    Mar 14, 2001
    1,222
    Abilene, Texas
    Looks good Fred, now all you need is a soft top and you'd be good to go
