Pics of the blazer after paint job
Discussion in 'The Garage' started by highlow, Jan 15, 2005.
  1. highlow
    highlow 1/2 ton status
    Oct 8, 2002
    124
    Keep in mind fellas I'm hoping I scratch the *#*@% out of this paint job so I can keep practicing:D I have since added 36" swampers and I have a full cage for it I have to just finish welding it and then paint more pics coming soon. Also since you guys are looking give me some advice on a inexpensive pair of lockers for my dana 44 and 12 bolt rear gonna have to keep these axles for a while until I stumble across something better
    EAT BEEF
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    awesome you have some good skills :)
  3. big_truxx
    big_truxx 1/2 ton status
    Oct 8, 2004
    2,272
    Canaan, Maine
    definately a nice paint job! If you are looking to do it on the cheap and want lockers I would go with lock rites.
  4. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,008
    841
    Pinckney, MI
    Nice work!!! :thumb: :saweet:
  5. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Nice work on those flames.
  6. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    Nice flames. Are those done w/ an airbrush, stencil, hand painted??? As for the cheapest lockers go, your local welding shop will do it CHEAP.... If you don't want em welded, LockRites are probably the cheapest way to go. If you are planning on running a very big tire you will break lots o front axle shafts w/ it locked up in the front.
  7. highlow
    Oct 8, 2002
    124
    Thanks guys, as for your question poohbair the flames are masked and painted and the skull is a stencil that you airbrush to give you the out line then you have to render it to give it teeth and the other small details. EAT BEEF
  8. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    nice work on the graphics.:thumb:
    for lockers, it sounds like your not plannning on keeping these axles forever, so i would just get a cheap lock rite for the rear. they install without removing the diff so its fairly easy to do. i would leave the front open for now. you'll notice a big difference in traction with just the rear locked. the front you'll just risk breaking parts with 36" tires. then when your ready to swap in 1 tons(which i assume is in your future) you wont have a bunch of money tied into the 1/2 ton gear.
  9. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,922
    333
    Fort McMurray, Alberta
    Looks good :)
    I hope you plan to staighten that fender up front right? The gap is pretty wide at the bottom...
