pics of the blazer
Discussion in 'The Garage' started by shupach, Jun 4, 2003.
  1. shupach
    shupach 1/2 ton status
    Dec 28, 2000
    648
    Dallas, TX
    i just got the front clip back on, here is a pic of the blazer vs the vw and the other pic is of my new header back "exhaust"
    and one more
    phill
  2. purple76pearl
    purple76pearl 1/2 ton status
    Jan 13, 2003
    450
    missouri
    thats quiet /forums/images/graemlins/rotfl.gif
  3. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    wow..id like to hear THAT go down the road!! /forums/images/graemlins/thumb.gif
  4. shupach
    Dec 28, 2000
    648
    Dallas, TX
    u just might, im going to Univ. of Rochester next year, while I cant have a car freshman year, i might take it up soph year.
    phill
  5. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Nice pic's. Do the Cat's from about a 6 square block area, converge on You place to Poop? By the look's of the kitty litter, they would be having a party out there at night. /forums/images/graemlins/shocked.gif /forums/images/graemlins/rotfl.gif
  6. shupach
    Dec 28, 2000
    648
    Dallas, TX
    BOWAHHAHAHAHAHA, actually the reason i put it there is because when i ran the engine for the first time i topped off the radiator and when i killed the engine i had a nice green fountain going, so in order to save the cats lives, i had to put kitty litter everywhere.
    phill
  7. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Just kidding /forums/images/graemlins/rotfl.gif
  8. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    Just a tip, while you may already know this, I feel I must mention it.
    Your auto tranny pan looks to be sealed with RTV. This is a major no-no. The RTV can breakoff/dissolve from the pan and get into valve bodies and such. Making for a very bad situation. I.E. no-go /forums/images/graemlins/wink.gif
    Otherwise, that exhaust should sound killer /forums/images/graemlins/thumb.gif
    John
  9. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    really!?..cool..tell me when ur out here ill have to come by and take a look at that thing! /forums/images/graemlins/thumb.gif
  10. shupach
    Dec 28, 2000
    648
    Dallas, TX
    John
    ya i know i need to swap it out, i had a bad experience when i tried replacing it, it went along the lines of having all the ATF falling on me, and then not being able to line the new gasket....I'll fix it though, i need to work on the flexplate which means im gonna either pull the tranny or just pull it back some.
    phill
  11. FL84K5
    FL84K5 1/2 ton status
    Aug 19, 2001
    936
    Sarasota, FL
    Where are your front shocks? /forums/images/graemlins/confused.gif
  12. shupach
    Dec 28, 2000
    648
    Dallas, TX
    i really need a set of shocks hahahaha
  13. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    What kind of compression are you running?
    Seems like you will loose alot of bottom end.........although it should shake the neighborhood /forums/images/graemlins/thumb.gif
  14. shupach
    Dec 28, 2000
    648
    Dallas, TX
    should be in the neighborhood of 10.8:1, i used the dyno simulator on my computer and it was reading max torqrue around 2500-3500 rpm which is good enough, it should have about 500 lb/ft according to the dyno.
    phill
  15. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    i have found my exaust solution. now i have flex pipe and nine dollar turbo mufflers on mine until it's finnished. i also love your roof,in the winter i had to let all the air out of the tires and push it in the garage with my 350 super duty, what a b*tch that was .
  16. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    WOW I bet that think kills your ears /forums/images/graemlins/thumb.gif But isent it just more fun that way? /forums/images/graemlins/grin.gif
    NOW ask some honda boy to get under you truck and have him watch your front drive shaft when you rev it up(in park) /forums/images/graemlins/grin.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif
