Pics of the line lock I found at the boneyard today....
Discussion in 'The Garage' started by Waxer, Sep 1, 2003.
  1. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    going to use this on my front brake circuit as an additional parking brake to go along with my rear mechanical setup.
    Paid all of 2 bucks for this... It came off this huge flat bed truck.
  2. Grim-Reaper
    7,385
    Atlanta
    Uhhhhh looking at the flare fittings used....that looks like it's for air not hydrolic. Air is only around 90-120 PSI. Hydrolic is 500psi and double flare.
  3. Waxer
    1,857
    Long Beach, CA.
    Its definitely hydraulic as I had to cut the thick rubber lines and drain out all the hydraulic fluid. If it were air then I obviously wouldn't have picked it up for my intended purpose. /forums/images/graemlins/smile.gif
  4. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    snip.... Hydrolic is 500psi and double flare.
    FYI, More like 1200 to 2500 psi depending on if late model w/ABS or not; said the former brake design engineer. Racing and most street stuff limits out around 1200 psi. Some rare ABS systems run up to 2500 psi.
