Pics of the partially labelled '90 Vette engine wiring harness.
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by 72Blazerod, Mar 13, 2003.
  1. 72Blazerod
    72Blazerod 1/2 ton status
    May 18, 2000
    264
    Vancouver, British Columbia, Canada
    Pics of the partially labelled \'90 Vette engine wiring harness.
    Well a mechanic I am not, but I have finally started taking my first baby-steps to get this TPI Corvette engine (which has been in the garage for just about a year) into my Blazer. I figured the fist step was to label all the wires. I am about half way now but I thought I would share a couple of pics with you guys. You can see the ECM sitting in the bottom left corner on top od a toaster box to prop it up. Every wire coming out of the ECM is labelled at both ends. Any suggestions or tips are welcomed!!!
    I hope you like the mess!!!
    Rod
  2. TheBlazerKid
    TheBlazerKid 1/2 ton status
    Apr 26, 2000
    259
    Raymond, Washington
    Re: Pics of the partially labelled \'90 Vette engine wiring harness.
    looks like your doin things right, I dont think that there is that many wires in my entire blazer. anywho keep up the good work! /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  3. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    Dang! I just labelled the ends that were in the engine compartment and left the ends at the ECU alone. You're quite enterprising, Rod!
  4. 72Blazerod
    May 18, 2000
    264
    Well, it may have been a bit labour intensive, but now I am sure I won't accidentally cut the wrong wire by accident. It also gave me a little more confidence to work on this thing now that I know how to use the manual to figure things out.
    Rod /forums/images/graemlins/k5.gif
  5. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color="blue">I have some really good engine diagrams. PM if you want them
