pics of what you used insted of conewashers on steering arms
Discussion in 'The Garage' started by spongeidys, Oct 5, 2005.
  1. spongeidys
    spongeidys 1/2 ton status
    Jul 6, 2005
    2,566
    Dillion, CO and Palmerton, PA
    ive completely killed the cone washers on my steering arm by trying to pry them off and hit them off but i finally got the arm off and i need something to replace my conewashers and none of the parts stores around here have them
    so what have you used and do you have pics of what you used to replace them?
    oh btw after whacking on the arm for 3 days i realized the studs screw out i took a vise grips and just threaded the bolts out and the arm came right off ;p
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    Ask around for some used ones. Call ORD. Check around. There out there.
    Don't try to skimp around without cone washers. They are too vital a part for steering to be taking shortcuts on. Is someone elses life worth your own?
  3. badfish4tail
    badfish4tail 1/2 ton status
    Mar 1, 2005
    1,684
    Long Beach
    I think I might have a set in my garage, pay the shipping and I will give them to you :D But let me make sure I have them first :wink1:
  4. spongeidys
    Jul 6, 2005
    2,566
    just let me know ;D
  5. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Parts mike has them.
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    You can NOT go with out the cone washers. I can't think of any other part that would totally prevent any side-to-side motion of the arm in relation to the knuckle. Any movement will weaken the studs until they break. If that happens at speed, you can kiss your a$$ goodbye, as you will have zero directional control... :eek1:
    The GM dealer sells 'em, as does www.offroaddesign.com and probably a few other off-road specialty shops.
  7. badfish4tail
    Mar 1, 2005
    1,684
    Long Beach
    Sorry didnt get home from work till late :mad: ...But i will look tomorrow ;)
  8. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
  9. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    You could call the guy that built the truck in this thread . He will know. :D
  10. 70jimmy
    70jimmy 3/4 ton status Premium Member GMOTM Winner
    Mar 3, 2000
    5,953
    248
    Released from Pueblo, told I belong in Southpark
    I am pretty sure I have a set, I will check tomorrow when I go work on my truck and let ya know in case the other offer falls thru.
  11. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    lol, somehow my D60 does just fine without cone washers. Locking tapered nuts are way better IMO. Anyone who has ever spent 6 hours trying to get rusted in POS cone washers out of a steering arm will probably agree with me. On the 60 ya just double nut 'em, lock tit'em and forget about it. Not sure why people don't do this on every other axle ever made but for some unknown reason toy / chebby half ton people "have" to use them. I have posted about this a few times on the pirate toyota board and have never ever seen a legit response as to why they'd be required over locking tapered nuts, assuming ARP or someone would make them. Considering how many "know it alls" there are over there... it seems that its just a matter of no one really thinking about it. I've never needed 'em for my k5 so I don't know if ARP makes a nut that would work.... but I wouldn't doubt it if they did.
    of course, using tapered nuts would probably require the steering arm itself be machined for a proper fit. Most D44 x-over arms are probably machined to use the cone washers which are deeper than a tapered nut would be. In any case, assuming you could get the correct taper in the arm, know how to use locktite and to properly torque a nut, it'd be way better than those pos cones... which are sorta like the ugly red-headed cousin of the locking washer (another POS, but at least they come out easily!).
    j
  12. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    X2 tapered nuts rock but, i am glad i did not have to deal with cone washers!!!!
  13. diesel4me
    Jul 24, 2003
    17,540
    930
    Massachussetts
    scary...
    A local "4x4" shop that installed a lot of lift kits used Ford 9/16" lug nuts with the 1-1/6" hex when installing a drop pitman arm on a lot of lifted trucks! :eek1: --but I don't recall them ever having any comebacks or lawsuits..but I don't think I'd do it that way..I did use grade 8 bolts on my 74 K20 instead of studs(couldn't find any new ones)..but I used the old cone washers over,and grade 8 flat washers too..and torqued the P** out of them!..after one salty MA winter,I doubt I could remove them again..Dorman does make those cone washers,but not many warehouses stock them.. :crazy:
  14. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    waiting for some of the engineering gurus to chime in on this...
    j
  15. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    so yer saying you need new stud too?
  16. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
  17. spongeidys
    Jul 6, 2005
    2,566
    no dont need a new stud the arm came with new studs but i whacked away forever on the arm and someone looked cloesly at it and informed me it was threaded in and i just took visegrips and threaded it out i wish i knew about that from the beginning the arm was off in about 5 mins that way ;D
    and thanks much to 70jimmy for the washers ;D
  18. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    Next time just use cone washer pliers (most parts stores sell or rent them) and use a butane torch on the old arm to expand it from the cones. It should only take 5-10 minutes max to get off an old arm. When You put in the new ones put a coat of never seize on the cones.
  19. 70jimmy
    Mar 3, 2000
    5,953
    248
    They are in the mail.
    Corey good info on the pliers, I had no idea they existed!!
  20. Corey 78K5
    13,055
    Humboldt County, CA
    Yeah A buddy showed Me once and it was one of the best tools I ever saw. I don't know any other company that makes them but I do know that OTC makes them Look Here Click on the 3 links at the bottom and You will really see how they work. Any special tool you need OTC probably has it. Oh yeah they work great for Toyota hubs as well.
