Pics posted*1-TON FOUND* conversion has begun!!! Ouch ! Broke rear axle on.
Discussion in 'The Garage' started by uglychevyZZ4, Aug 1, 2002.
  1. uglychevyZZ4
    uglychevyZZ4 3/4 ton status
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    **UPDATE**1-TON FOUND* conversion has begun!!! woo-hoo!
    This wasnt good, going home today on Hwy-18 here in Wa, a long deadly hill, i felt a minor vibe, not usual for my rig since they annoy me and so i cure them. I pull over and look, all seems well, figure i just lost a wheel weight.?
    Then I go to leave the side of the road, and wont move... Hmmm? odd... tranny gone maybe? so i lock it in, and it moves. So I get to the next exit, and as im cornering i notice the L.R. axle seeming to be out maybe 2" farther than normal /forums/images/icons/shocked.gif . i pull over and it is barely on the drum /forums/images/icons/shocked.gif , no roll-bar /forums/images/icons/shocked.gif , 8 yr old playing co-pilot, and two toddlers in the back seat with the top off !!! /forums/images/icons/frown.gif
    Thank god It didnt come out down hill on the freeway ! WHEEEWWW!!!I'll keep ya'll posted. Maybe good time to hang that 14FF underneath it /forums/images/icons/smirk.gif
    Havent been wheelin in maybe a month, why would this break just going down the freeway? I have a Corp.. D44 with a Eaton H.D. posi.
  2. jc71355
    jc71355 1/2 ton status
    Jan 13, 2002
    830
    Port Neches, Texas
    Re: Ouch ! Broke rear axle going down freeway..4x4\'ers must have angels.
    Maybe the C-clip worked its self loose and fell out. Glad that everyone is ok though.
  3. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    Lucky you! /forums/images/icons/shocked.gif Glad everythings gonna be alright.
    Bill C /forums/images/icons/cool.gif
  4. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    FULL-FLOATER AXLES ARE GOOD.......
    Losing a wheel and axle on the trail is an inconvenience, losing one on the street is deadly! Glad it all worked out safely, and YES by all means get a 14BFF under that truck ASAP!!! /forums/images/icons/grin.gif
  5. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    Whats a Corp d44? you mean a 12bolt? heh, as for the axle breaking, was it broke? or was the c clip missing and the splines are all still ok? kinda hard for the c clip to come out unless that center pin breaks isnt it?
  6. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    It is a corperate 12 bolt. or d44, same i think..? /forums/images/icons/confused.gif
    either way, it snapped, and we are lucky we got off the freeway b4 it came out completely! here is the carnage pic, i canr believe such a in-expensive part dosent have more protection from killing a entire family. /forums/images/icons/mad.gif
  7. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    If you're going to keep running a "C-clip" axle get the kit that gets rid of the C-clips.
  8. thatK30guy
    Jan 12, 2001
    32,076
    55
    For a '77 Jimmy, that would be the corporate 12 bolt rear and the front would be the D44. /forums/images/icons/wink.gif
    Good thing you pulled over to inspect the truck rather than trying to make it home. /forums/images/icons/wink.gif
  9. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    ya, i need to know what 14ff will bolt right in in lue of moving spring perches..??????
  10. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    its gonna be a while(more like long while) before I am going to be able to upgrade to full float axles, what is this c clip kit and what does it do exactly...I've heard a little about it, but not much.
  11. thatK30guy
    Jan 12, 2001
    32,076
    55
    In order to bolt right in place of the 12 bolt, get any 14FF out of a 3/4 ton truck, either 2wd or 4wd will work fine. /forums/images/icons/wink.gif
  12. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Sure glad to hear that you and the kids are ok man!!!
  13. thatK30guy
    Jan 12, 2001
    32,076
    55
    Not "c-clip kit", but the c-clips are what hold the rear axle shafts in to prevent them from sliding out, like what happened here.
    C-clips are the weak link in any 10 and 12 bolt rear axle. They are ok for stock trucks with no lift and small tires, but once the opposite has been added to the truck, the stress is too great for the c-clips to handle. /forums/images/icons/frown.gif
    There are aftermarket kits available called "c-clip eliminators", which simply put, you cut the ends off at the backing plate end and reweld the new ends that come in the kit. What the new ends do is hold the shafts in place via a pressed on seal/bearing assembly and also a flange which bolts to the new flange that was welded onto the cut off flange part of the housing.
    These set ups are very much like the Ford 9" rears.
  14. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> The problem with c-clip eliminator kits is that they're generally intended for drag racing applications, they are not designed to take the side=loading present in offroading. You're more likely to break the eliminator loose than to break the c-clip.
    As for the shaft breaking on the freeway, I've seen more broken semifloater shafts on the street than I have off road. It's one of those things, when they are finally fatigued enough to break, they just go when they go. </font color>
  15. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    hmmmmm....what to do since I won't be able to afford FF axles till next yr at the earliest.
  16. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    not a bad time to get that cage too....could you imagine rolling at 60 mph? whew...
  17. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    Ya i know, the thought of that will keep me awake for days /forums/images/icons/frown.gif
  18. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    So, i found a 4:11 -14FF, and i just bought shaggy's 4:10 front set, are these 2 gears actually the same ratio? can i run them together? ( in mud, not street racing of course ) .. /forums/images/icons/grin.gif
  19. tRustyK5
    Jul 23, 2000
    36,188
    1,396
    E-town baby!
    Yes you can. Most front/rear ratio's from the factory differ by a little. Front ratio's are commonly 4.09:1, 4.10:1 and 4.11:1 and any of these can be run with a 4.10:1 rear. The ratio difference is less noticable than having slightly different air pressure front and rear.
    Rene
  20. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    I watched an axle come out of a Dodge one time up on I-680 in the Bay Area few years ago. Everyone was smart and slowed down and way behind the guy, and luckily when the axle finally came out at about 50 mph, the truck didn't roll and the tire with axle hit the center divide and stayed on our side.
