Pics
Discussion in 'Pacific Region' started by Tweetysuarus, Apr 9, 2004.
  1. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    Broken Pinion Gear
    Fully disassembled
    Aaron installing new ring gear with loc tite
    New pinion with shims and bearing
    Bearing being pressed on the pinion
    Installing the locker with the new gear
    Checking the shims
    Setting up a dial indicator, not zero'd yet!
    Backlash set at .006
    All this wouldn't have been possible without the help from Aaron! /forums/images/graemlins/bow.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/waytogo.gif /forums/images/graemlins/peace.gif He da man! This was an all day project. We had to disassemble the rearend and remove the gear set to swap for the new set at 4 Wheel Parts. The removal of the locker was not an easy task, the preload was very tight as well as the pinion removal was quite tight as well. Well the parts were supposed to there at 10am, But you know how that goes! /forums/images/graemlins/angryfire.gif They did arrive on time so we went to pick up new axle seals and get lunch while we waited for the truck to arrive. Finally we get the gaerset and headback to do the install after cleaning up all the parts. Aaron installed the new gear on the locker and pressed the new bearing on the pinion after he measured the shim thickness and set the pinion depth, we got lucky the first time and got a good reading! /forums/images/graemlins/woot.gif /forums/images/graemlins/waytogo.gif,Next was to setup the back lash in the locker. Once again frist time with .006 on the dial indicator! /forums/images/graemlins/woot.gif /forums/images/graemlins/waytogo.gif /forums/images/graemlins/peace.gif! Then came the hard part! /forums/images/graemlins/yikes.gifInstalling the crush sleeve! /forums/images/graemlins/yikes.gif What a pain in the buttkis! /forums/images/graemlins/yikes.gif When we started to get the crush sleeve to compress the first bit was quite stuburn and we could only get about 1" of movement in the breakerbar! /forums/images/graemlins/yikes.gif But Aarons persistance won out over time after several breakerbar feild goals /forums/images/graemlins/whistling.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/yikes.gifBut he didn't give up and finally got the pinion preload done /forums/images/graemlins/bow.gif /forums/images/graemlins/bow.gif /forums/images/graemlins/peace.gif /forums/images/graemlins/peace.gif! We then had the final clean up and fill with oil and test drive! /forums/images/graemlins/woot.gif /forums/images/graemlins/waytogo.gif!
    No problems so far! Aaron is da man! /forums/images/graemlins/bow.gif /forums/images/graemlins/bow.gif /forums/images/graemlins/bow.gif /forums/images/graemlins/bow.gif
    Thanx Aaron!
    Bill
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Cool deal, glad to hear everything went relatively smoothly for ya /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif
  3. Tweetysuarus
    May 25, 2002
    2,294
    Lynnhood,WA
    Yup! I can't wait for the break in procedure to be over with! Where are the little elves in the middle of the night to do this while I sleep! /forums/images/graemlins/histerical.gif
    Bill
  4. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    Nice photos, but I don't see any of it on the trailer with those bad a$$ wheels and tires /forums/images/graemlins/rotfl.gif /forums/images/graemlins/peace.gif
  5. Tweetysuarus
    May 25, 2002
    2,294
    Lynnhood,WA
    I fergot on purpose! /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif Couldn't get myself hammered on for weeks for the NHRA look!
    Bill
  6. clubba68
    clubba68 1/2 ton status
    Dec 6, 2002
    1,511
    Eugene-Portland, Oregon
    Sweet pics. Looks like you could be a 4x4 mag photographer. /forums/images/graemlins/thumb.gif
  7. Tweetysuarus
    May 25, 2002
    2,294
    Lynnhood,WA
    I wish, They make bank!
    Bill
  8. uglychevyZZ4
    uglychevyZZ4 3/4 ton status
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    /forums/images/graemlins/thinking.gif Aaron, beardless? Thats just unheard of!!!!
  9. 4xrick
    4xrick 1/2 ton status
    Sep 14, 2003
    1,102
    kirkland Wa
    it is summer i think he wants to keep cool or seem cool i dont know which
  10. ntaj*ep
    Feb 4, 2002
    3,248
    Evergreen state
    Hay now, lets take it easy here. I never claimed to be cool although the air has been getting a bit warmer lately......
  11. 4xrick
    Sep 14, 2003
    1,102
    kirkland Wa
    hey i never said you claimed to be cool I said you were trying to seem cool dont be getting all confused now. /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  12. Tweetysuarus
    May 25, 2002
    2,294
    Lynnhood,WA
    Now, now no more [​IMG][​IMG][​IMG][​IMG]
    Bill
