picsExtended (at least 8") slip dshafts (front and rear) both with CVs (AZ)
Discussion in 'General Parts for Sale' started by juanblzer, Jul 27, 2003.
  1. juanblzer
    juanblzer 1/2 ton status
    Sep 12, 2001
    1,614
    9
    Chandler, Arizona
    picsExtended (at least 8\") slip dshafts (front and rear) both with CVs (AZ)
    pics:
    http://coloradok5.com/photos/showgallery.php?cat=9454&ppuser=3311
    the pics that are good are called reardrivshafts etc.
    These prices are totally flexible! I need the money.
    These are both used Arizona Drivelines shafts. They are set up for use on a 4inch lifted blazer with a 208 and 700r4 with a small block and Dana 60/ 14bolt.
    Both shafts are "used" and need u-joints and possible builds of their respective cv's. They would be great on a trail only rig. I like driving on the highway and these shafts are not made for that.
    Sold as is, they are used.
    Working length for front (on my rig was 32" rear and 36" front) the spline is long enough for some major play in longer or even shorter set ups.
    40 bucks each or 75 bucks for both plus shipping or best offer
    /forums/images/graemlins/grin.gif
    also: two driveshafts out of an 89 k1500 gmc longbed. Stock as is 20 bucks each
  2. juanblzer
    Sep 12, 2001
    1,614
    9
    Chandler, Arizona
    Re: Extended (at least 8\") slip driveshafts (front and rear) both with CVs (AZ)
    price has been reduced.
    ttt
  3. Mreetz
    Mreetz 1/2 ton status
    Jun 26, 2001
    1,282
    Subs of Denver, Colorado
    I need one for a 208 setup and a 4" lift. Will one of these work on my '84 K5? /forums/images/graemlins/thinking.gif
    They won't work well for highway driving?
  4. juanblzer
    Sep 12, 2001
    1,614
    9
    Chandler, Arizona
    they were not made for highway driving. THey are stout drivelines but if you see high speeds, no they are not for you. For the price they are great trail spares. Replace the ujoints and rebuild the cv and you are good to go. There is still plenty of spline engagement on the slips
  5. juanblzer
    Sep 12, 2001
    1,614
    9
    Chandler, Arizona
    Re: picsExtended (at least 8\") slip dshafts (front and rear) both with CVs (AZ)
    new pics
    ttt
  6. 88K5Jimmy
    88K5Jimmy 1/2 ton status
    Jan 10, 2001
    1,323
    Tulsa OK
    Can you give me measurements, extended, collapsed, and how long the slip is, on the extended np208 front shaft? Also, is there any slop in the spline engagement?
    Ross
  7. juanblzer
    Sep 12, 2001
    1,614
    9
    Chandler, Arizona
    the male spline is 15" of spline
    29"-30" compressed (that's not bottomed out)
    37"+ extended
    Yes, there is some slop. It still works fine but need rebuild of cv and new joints. These shafts were over 500 each from Arizona Drivelines. The rear has a bolt on yoke for a 208 (one would just have to drill and tap his tailshaft). However, these are used. THey have no dings or damage but they are NOT meant for Highway use. /forums/images/graemlins/tongue.gif
  8. the excuse
    the excuse 1/2 ton status
    Dec 9, 2003
    209
    san diego
    hi i saw your driveshafts for sale. i have a 83 blazer with 350 engine and 350 trans. it has a 208 case in it. will the front driveshaft fit? i measured from the center of the flat output on the t case to the center of where the u joint would be on the dana 44 (the driveshaft was not in. i measured with a string so it was a straight line lengh, and the car was parked, not jacked up or anything.) these measurements would be the same as measuring your drivshaft from the tip of the flat flange to the farthest part of the u joint cap. i have 4 inches of lift, will it contact the crossmember at full droop? could the shaft possibly be too long and break my t case if i bottomed out? will the u joint bolt up the the dana 44? i do highway driving so would it be possible to put the cv into the driveshaft i have right now. it has the standard u joints in it, does yours use these? if i did just put the cv in would it help smooth the ride? how much lenght would i gain from putting it in. thanks sorry for all the questions.
  9. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    How much would shipping be for the 2 driveshafts to 93312?
  10. the excuse
    Dec 9, 2003
    209
    san diego
    i got fist dibs, even though this post was from last year. i meant to pm him not make a post /forums/images/graemlins/shocked.gif
  11. Esteban86K5
    3,712
    Bakersfield, CA
    [/ QUOTE ]Not a problem, but if you don't want it I would still ike to know what the shipping would be. Although I hadn't noticed that this post was from last year. /forums/images/graemlins/tongue.gif
