Picture: Low compression cylinder
Discussion in 'The Garage' started by mountainexplorer, Jan 17, 2005.
  1. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    Think this cylinder has low compression?
    I had this gut feeling the sound of pieces dropping into the oil pan was what was left of a piston.
  2. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    rings are still good:haha:
  3. big_truxx
    big_truxx 1/2 ton status
    Oct 8, 2004
    2,272
    Canaan, Maine
    when the pic was loading (yes im on dialup :p:) it looked like there was a stream running out from the cyl wall next to the hole. I was going to say I found your problem someone left the cyl cooler switch open... but then I saw it was really a ring! :yikes: How'd you blow that piston up?
  4. mountainexplorer
    Nov 14, 2001
    4,903
    I was told this motor was "bad". When I got the truck home, I went to try and start it to see how bad. It fired once. Then fired a 2nd time (priming it with gas). Then it pulled fuel up, fired and ran for a bit once it pulled up fuel. It was making a not so loud clatter. Then all of a sudden, after about 10 seconds of running, it sounded like a big backfire, and it died. Wouldn't spin over anymore.
    I drained the oil... and 2 gallons of coolant came out before oil (there wasn't any water on the dipstick when I first tried starting the motor).
    I'm thinking a wristpin was the initial culprit. Then when I fired it trying to make it run it must have shattered then.
  5. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    Congrats on a Job well done!
  6. big_truxx
    Oct 8, 2004
    2,272
    Canaan, Maine
    :waytogo: well at least ya had fun blowing it up right? It's all that matters.
  7. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    What's wrong with ya? Loads of life left in that! Now when I was in the war......:grin:
  8. mountainexplorer
    Nov 14, 2001
    4,903
    To the right person, it would still be worth having the one cylinder sleeved. The rest of the cylinders are all standard and the crank is standard.
  9. diesel4me
    Jul 24, 2003
    17,568
    943
    Massachussetts
    "right persons" hard to find lately--
    Its not easy to find someone willing to buy an engine that needs a sleeve,unless its a rare block or they want matching #'s ,but you never know.....but the bright side is.........
    Scrap is 75 bucks or more a ton here,might be more in your area--that motor will still buy your groceries for a few days,even it its current state of disrepair....:grin:
  10. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    NICE!
    Reminds me of a story that a guy I work with told us. He was an armored-vehicle mechanic with 1st Armored Division in Iraq; they had a bridge-launcher take a hit and come in (under it's own power) for repair. The bridge launcher is powered by an air-cooled 12-cylinder Continental diesel, and each cylinder has it's own "jug". Well, whatever hit them took out an entire jug, right where the jug bolts to the crankcase.
    The motor still ran!
    He said it sounded like s**t, but it ran. Said it was insane to stand there and watch the crank throw for that jug spinning in a no-BS running diesel engine.....
  11. dirtwarrior17
    dirtwarrior17 Banned
    May 14, 2004
    1,820
    Redding, CA
    2 stroke conversion>:saweet:
    Or did you get tired of water cooled and switch to air? lol.
    What ever happened to the old two stroke diesels?
