Picture(maybe a drawing) of NP203 Shifter ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Executioner, Jun 2, 2000.
  1. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Someone posted a picture(maybe a drawing) of a NP 203 shifter, and the adjustment holes for lining
    up the linkage, can someone please repost it or give me the link.
    Thanks alot
  2. Neko H
    Neko H Registered Member
    May 31, 2000
    21
    Texas
    Hey Executioner
    mudfanatic posted a drawing it's at http://www.coloradok5.com/forums/files/3-18157-dsc00013.jpg
    It was posted along with the the post My t-case it too hard to shift why???
    I found this thread looking for info myself I have a post out there now Transfer case question. Sounds like you are planning on doing the same thing as me. Let me know how yours works out and I'll do the same. I hope to work on it tonight ..... but have to check with the wife if I can play or not.
    Neko H
    79 GMC Jimmy 4x4
    (If I'd only win the Lottery, it would be Cherry)
  3. Neko H
    May 31, 2000
    21
    Texas
    Hope you had better luck than me. I checked the linkage set the pin with the NP203 in neutral. The levers from the transfer case pointing down at 6:00. All is well there, checked the oil pulled the fill plug oil seeped out so all is well there. BUT I STILL have only Low, Neutral, & High NO Loc that I can find.
    ANY Ideas??????
    Neko H
    79 GMC Jimmy 4x4
  4. EDdaTREE
    EDdaTREE 1/2 ton status
    Feb 18, 2000
    1,253
    Austintown, OHIO
    Watch the shifter and linkage from underneath as somebody runs it thru the positions and see what its TRYING to do....maybe you can fiddle the adjusting nuts and get it to drop into LOC.Also, are you sure you're NOT getting into LOC? I (think) that if its in LOC, then both driveshafts should lockup together. Also, try going for LOC when in neutral and coasting slightly on a hill. good luck
  5. Zack
    Zack 1/2 ton status
    Feb 18, 2000
    329
    IL, USA
    I have a very nice picture from a book of mine but my scanner doesn't work , sorry. But if you have a borders/or similar book store around you you can take a gander at the picture in the book. The title is : Turbo Hyadra-Matic 350 Handbook by Ron Sessions, the picture is on page 217, it explains how to adjust the control linkage. Wish I had a scanner so I could send it to you without making you go to the store. By the way the book is very good. I am gonna rebuild one of my 350's (tranny) this summer so I thought I better read up on it.
    <font color=red>Zack Carlson</font color=red>
    <font color=yellow>Carlson@thestix.net</font color=yellow>
  6. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    Heres one for ya.
    Hey there, I have scanned a picture from my Haynes manual for ya. Check these out if they are of any help.
    <font color=red>Mudzer</font color=red>
    1978/91 K5 Blazer
  7. Mudzer
    3,639
    Missouri
    Re: Heres the instructions too
    Heres the instructions straight from the Haynes manual.
    1978/91 K5 Blazer
  8. Executioner
    Feb 22, 2000
    1,530
    Yes this is the one I was after.
    Does anyone have a shifter without the alinment hole/notch ?
