Picture needed of Th400 OD switch mounted.
Discussion in 'The Garage' started by keith, May 9, 2005.
  1. keith
    keith 1/2 ton status
    1,158
    La Fayette, GA
    Can some one show me how that thing goes in. Been looking at it and it needs to be it put in. Thanks
  2. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    OD switch? if OD stands for overdrive, a th400 aint got overdrive. Can someone school me if it stands for something else?
  3. dremu
    Feb 27, 2000
    15,970
    462
    East of San Francisco
    Jah, I'm thinking the OP meant the kickdown switch.
    -- A
  4. keith
    1,158
    La Fayette, GA
    What ever its called I still need a picture. Yes I know it has 3 gears.
  5. moneypit
    moneypit 1/2 ton status
    Sep 3, 2000
    1,382
    COLORADO
    Is yours pedal operated or up by the carb/tbi linkage?
  6. keith
    1,158
    La Fayette, GA
    Its a switch by the pedal
  7. moneypit
    Sep 3, 2000
    1,382
    COLORADO
    Don't know about that one but I do however have the B&M one that hooks up to the tbi linkage that is electronic, not that old. I don't need it anymore due to manual valve body. If you can't figure it out let me know. I will be posting it up for sale as soon as I have time to remove it. I will make it right for you though. Peace-out
  8. keith
    1,158
    La Fayette, GA
    When you put this on did you notice any difference? And why did you go to the manual valve body?
  9. moneypit
    Sep 3, 2000
    1,382
    COLORADO
    The k5 had a 700r4 in it. I swapped in a th400/doubler and had no kickdown/passing gear, had to pull it down manually. I added the switch and all was good. I just recently cracked the th400 and had to replace it, so I went with a Art Carr reverse -pattern manual valebody. It will no longer shift itself so the switch is no longer needed. The switch has 2 wires 1 to power 1 to trans. It operates of the tbi linkage, there is a spring attached that pulls on the solenoid deal that sends a signal to trans to kickdown. You still need to adjust it but it's simple. Got it from Summitt for $50???ish...
  10. 77crewcab
    77crewcab 1/2 ton status
    Feb 9, 2004
    1,620
    Lubbock, Texas
    Dont have a pic but I can describe how it goes. From the trans tunnel side put the switch in the hole on the pedal bracket with the peg towards the trans tunnel and the metal mounting bracket hole down. It really only goes one way from what I can tell.
  11. thebigdaddyof2
    thebigdaddyof2 1/2 ton status
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    Yep, pretty straightforward.
    The switch mounts in the throttle pedal bracket as stated above.
    The throttle pedal arm pushes on the peg of the switch when "floored" and sends +12v down to the T400 to indicate the need for passing gear.
  12. keith
    1,158
    La Fayette, GA
    Thanks I will look at it tomorrow.
  13. mrk5
    Apr 20, 2004
    12,351
    1,051
    Northern Colorado
    This is the only one I have:
    Hope it helps at least a little.
  14. keith
    1,158
    La Fayette, GA
    I was looking at the lower bolts. Makes perfect sense now. Cool. I was just figuring it may have been different in a blazer. I will have it in today. Thanks for everything :grin:
  15. keith
    1,158
    La Fayette, GA
    Now I also see why i missed it. Had several things zip tied to it. Radio wires,ecu harness. :)
