Picture Request - Trucks On 40" Or So Tires With Little Backspacing
Discussion in 'The Garage' started by Resurrection_Joe, Jan 28, 2004.
  1. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Picture Request - Trucks On 40\" Or So Tires With Little Backspacing
    I'm thinking about having some 15x8 2.5 BS 8 Lugs made
    I plan to run 39.5 IROKS or 39.5 TSL Bias
    I'd like to see if anyone is running a wide 38, 40, 42 inch tire on 3, 2.5, or 2 inch backspacing
    Lift doesnt matter as long as whatever truck it is has a full width front clip for reference
    Front shots please
    I'd like to see if it looks rediculous and where it might hit the fenders
    Thank you for your patience, I'm going back to wade through the members galleries
  2. big k5
    big k5 Registered Member
    Nov 19, 2003
    88
    Sautee Nacoochee,Georgia
    Re: Picture Request - Trucks On 40\" Or So Tires With Little Backspacing
    Well I don't have any pics,but i'm running 18x39's on a 15"x 14"wide alcoa rim & if I had to geuss they only have about a two inch backspace.They stick out past the fenders probally 12"? This k5 has a 12" lift,NO body lift and the tires will still hit at the rear corner of the front fender,just trying to go through a small ditch,I figure bushwacker cut-out flares should solve the problem.But I'm also toying with the idea of setting the truck down to 6 or 8"s of lift with smaller tires.The truck was this way when I bought it.I personally think it looks good,but it's not real practical.Hope this helps you some,Bruce.
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Mind if I ask where you are gonna have those rims made? I want to run a 2.5" back spacing with my 39.5 IROKs, and 15x8s would be perfect cause later I will install Rockstomper beadlocks.
  4. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    I don't know if it helps any because I'm running 35's and 16.5's but they are 14 inches wide and I have about 3.5" backspacing. At least help you see how wide they will stick out. [​IMG]
  5. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    Rezzy Joe,
    Check my Members ride area, there are pics of my truck with the 39.5" IROK's and 3" backspacing.
  6. jekbrown
    May 19, 2001
    45,029
    362
    Vancouver, WA, USA
    39.5 tsls on eaton 15x10 rims with 2.5" of bs...
    j
  7. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    j
    [/ QUOTE ] I didn't know you had only 2.5" BS /forums/images/graemlins/blush.gif...thats less than me. How bling of you. /forums/images/graemlins/grin.gif j/k
  8. Topdown
    Topdown 1/2 ton status
    Nov 26, 2002
    2,598
    Vancouver, Washington, U.S.A
    Every time I see your /forums/images/graemlins/k5.gif it makes me want a bigger lift/tire combo... damn you! /forums/images/graemlins/peace.gif
  9. supersize75
    supersize75 1/2 ton status
    Sep 27, 2002
    2,638
    gilbert az......by Phoenix
    38's and 3.5 BS
    I love 2.5, very little grinding for calipers and I can still fully stuff the tires /forums/images/graemlins/thumb.gif
  10. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    A 15x8 rim with 2.5" BS will stickout the same as a 15x10 rim with 4.5" BS...in other words, not much.
  11. mud390
    mud390 1/2 ton status
    Oct 31, 2002
    1,210
    Little Rock, Arkansas
    How much lift are you running Supersize?
    Kris
  12. supersize75
    Sep 27, 2002
    2,638
    front..
    6 inch bds, d60 provides another inch too
    rear, 2.5 inch skyjacker springs, and echo bit flip
    cab..3 inch body lift... /forums/images/graemlins/histerical.gif
    The bodylift helped me stay soft and still get clearence so I dont hate it very much, I now dont have it on the core support though, just the cab. /forums/images/graemlins/grin.gif
  13. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Here are some pics of mine 39.5x18-16.5 boggers not sure of the backspacing though.
