Pictures of breakage...that explains why my 6.2L sounded so funny :(
Discussion in 'The Garage' started by steelsoldiers, Mar 24, 2004.
  1. steelsoldiers
    steelsoldiers 1/2 ton status
    Oct 17, 2002
    365
    Charleston, West Virginia
    Hey guys,
    I finally got to the root of my engine troubles in my M1009. Just a brief recap for those who didn't see my earlier posts.
    I was driving my M1009 a few months ago and when I pulled up next to my deuce in the driveway, it just died all of a sudden. I tried to restart, but no good. I notice that my electric fuel pump wasn't running so my first thought was that it conked out and the injection pump lost its prime. I replaced the pump and bled the air up to the injection pump. I cracked the injector lines and cranked the engine over. I got a little diesel at a couple of the injectors, but never at the rest of them. While cranking to bleed the air the engine started making funny popping noises up through the intake. Weird huh? Well I tore the front of the engine down thinking there was something wrong with the timing. I discovered that the cam bolt had vibrated out allowing the pump driving gear to fall away from the pump gear. Dang. Well, I put it all back together and it started real quick, but it was making a machine gun racket sound out of the intake. I shut it down real fast. Today, I pulled the valve covers off looking for bent valves or something. The left side was normal, but when I pulled the right cover off, I saw some serious carnage. Check this out:
    I am thinking that the engine must have jumped time because the timing gear lost index on the cam shaft when the bolt came out. The pistons met the valves and busted the rocker assembly into pieces. It's strange that it only affected the right side. I would have expected bent valves or push rods, but damn, not a busted rocker shaft. I'm guessing there is also some serious internal problems on that side with the valves and maybe pistons so I will end up pulling the engine instead of just bolting up a couple of rocker assemblies. I figure the driver's side has problems too. Well, now I have been through everything with this Blazer, maybe.../forums/images/graemlins/crazy.gif
    Chris
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    ouch /forums/images/graemlins/yikes.gif /forums/images/graemlins/yikes.gif
  3. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    If you need a new one I got you covered. Just PM me /forums/images/graemlins/waytogo.gif
  4. steelsoldiers
    Oct 17, 2002
    365
    Thanks! /forums/images/graemlins/smile.gif I may have it covered though. I talked to a guy who's selling a rusted out 3/4 ton 4x4 that has a Jasper rebuilt 6.2L in it. Supposedly it has real low miles on it too. I'm going to check it out after work so keep your fingers crossed guys.
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I would pull the head and see if the pistons are messed up. Chances are that they're not and you'll just need one head and associated gaskets.
  6. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Looks likea big boo-boo /forums/images/graemlins/rotfl.gif /forums/images/graemlins/yikes.gif /forums/images/graemlins/yikes.gif
  7. AgDieseler
    AgDieseler Certified Scrap Producer Premium Member GMOTM Winner
    Jan 25, 2001
    1,038
    1,106
    Dallas
    I've heard of a lot of people with early (82-83) 6.2Ls break those cast rocker arms. /forums/images/graemlins/frown.gif The later design used stamped steel rockers, and they were used all the way into the 6.5L years. Weight is the same, but reliability is much improved with the new style rockers. Hope everything else is okay, and it runs strong again in the neat future! /forums/images/graemlins/thumb.gif
  8. steelsoldiers
    Oct 17, 2002
    365
    Hmmm /forums/images/graemlins/thinking.gif I have heard from another guy that some engine manufacturers designed the rocker shafts to break vs. the valves or pushrods, but I don't know about that. Both rocker shafts broke where the holddown bolt went through the shaft and there was not a lot of material there as you can see from the photos. I don't know, maybe they were fatigued from the 150k hard miles and just snapped when stressed like that. I have never seen that before, but strange things happen I guess. /forums/images/graemlins/dunno.gif
  9. OrangeCrushK10
    OrangeCrushK10 1/2 ton status
    Jan 25, 2003
    1,425
    Square State + Suspension Item
    I agree with Tim. Don't toss the engine. Pull the head and check out the pistons. You may only need to replace one or no pistons.
    So with a couple replacement parts you could buy the truck with the Jasper engine, swap the Jasper engine for your current engine, fix and put your current engine in the ex-Jasper truck and either re-sell it to make some of your money back or just keep it as a spare vehicle.
    And if nothing else, the block and crank could always be salvaged.
    Just a thought to try and save you some cash!
  10. steelsoldiers
    Oct 17, 2002
    365
    Yeah that's good thinking. After I pull it from the Blazer and get it on the stand I'll be able to check things out a lot more. We'll see what it looks like on the inside. I'll either keep it for a spare or put it in the K20, I could use another beater /forums/images/graemlins/wink.gif
  11. Diesel Dan
    Diesel Dan 1/2 ton status
    Feb 27, 2002
    798
    Warren, Ohio
    If you want to save it for later then pull the pan first. I've seen the blocks crack at the main webs with as little as 70K on them. Crank and balancer were still good.
  12. steelsoldiers
    Oct 17, 2002
    365
    I have heard that too on the DieselPage. I was on a site the other day that sold stud girdles for the 6.2L. Might be a worthwhile investment for the rebuilt 6.2L /forums/images/graemlins/thinking.gif
  13. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    cool..pics
  14. bear76
    bear76 1/2 ton status
    Oct 16, 2005
    1,065
    here
    See that avatar of yours. That's what the original poster looks like now:haha: , this thread was way old!
  15. supersize75k5
    Feb 3, 2004
    8,832
    4
    gilbert az
    i have no idea what your talking about, I am a fan of recycling:D
  16. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
