Pictures of CV slip yoke shafts
Discussion in 'The Garage' started by CyberSniper, Dec 9, 2003.
  1. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Does anybody have any pictures of a rear CV slip yoke shaft? I'm mostly interested in the slip yoke part.
    -Brian
  2. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    look in my gallery - i can't link to it on this computer (can't copy and paste picture links for some reason) it's on the second page.
  3. Jays Beast
    Jays Beast 1/2 ton status
    Aug 7, 2002
    538
    Chandler, AZ
  4. 88jimmy4x4
    88jimmy4x4 1/2 ton status
    Oct 19, 2003
    947
    3
    Houston, Texas
    Heres mine that I had installed on my stock d-shaft.
  5. 83_chevy_blazer
    83_chevy_blazer Registered Member
    Nov 18, 2003
    20
    i was thinking about making a cv. would it be possible to atach the cv part from the front driveshaft on my np208 to my rear driveshaft. it would fit in between the slipyoke and the shaft, adding the extra length the four inch lift i have needs. im thinking all i would need are some new U joints. would this wourk or is stuff going to explode?
  6. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    that's not how slip yoke CV's work. you need a slip yoke out of a caddy. it's an enclosed rectangle that holds the ball in the middle. hard to explain.
  7. 83_chevy_blazer
    Nov 18, 2003
    20
    that does sound hard to explain but im still wondering if my idea with the front shaft will work.
  8. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    What year/model Caddilac does it require? That's the exact piece I've been trying to find. Does it use a 1310 universal joint?
    I don't need the "ultimate" in strength or angle, I just need something to get rid of vibration problems caused by my pinion being pointed up.
    Thanks for the info
  9. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    The NP208 front shaft is flange (Saginaw) type whereas the rear is open yoke (Spicer) type.
    Not to mention the front shaft uses a significantly smaller universal joint than the rear 1310 joint.
    I'm working on making a list of parts to make your own custom slip yoke CV shaft. I've got a list of parts to make it work right now but it's really expensive because of having to assemble a bunch of parts to make the slip yoke.
  10. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    I'm not sure. I'll sell you my old shaft. It needs a new H-yoke though and a new cup on the slip yoke side. i'll get a picture. it's a 1350 rear joint and yoke.
  11. edlavarreda
    edlavarreda Registered Member
    Nov 26, 2002
    56
    70 to 79 deville $18 bucks at the junk yard san diego driveline modifided for $150 bucks NO MORE PROBLEMS
  12. nomadman
    nomadman 1/2 ton status
    Oct 6, 2004
    168
    Enfield, Ct
    Any chance you could send me the list? I need a low $$ short term fix.
  13. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Jesse does not use the cadilac CV. It is a poor idea as it only has splines about halfway down the yoke.
    Jess's yokes have splines all the way to the end.
  14. ColAdo82K5
    ColAdo82K5 1/2 ton status
    Feb 18, 2000
    789
    MO
    Hey,
    I am using the Cadillac CV shaft on mine as well. It is missing some of the splines on the slip yoke, but I have 6 inchs of lift, have flexed it out pretty good and have yet to hear anything funny going on. I'm about to swap in some flexy 56's so I will see if it brings up any problems.
    The seal on the back of a 208/241 happens to be the exact same part number as that on the old 79 caddy th-400 tail seal...that crazy GM is at it again.
    Here is a pic
    http://community.webshots.com/photo/61561424/121637085KDuVjy
    Top is the caddy shaft.
    Then a a lengthened shaft for my 6 inch lift
    Bottom is dead stock shaft.
    I use the middle one as a spare. I get some slight t-case noises on deaccelleration about 40 mph with it in. I used to run it before my shackle flip.
    Blake
  15. nomadman
    Oct 6, 2004
    168
    Enfield, Ct
    Do they sell yokes to fit the Caddy shafts, or just complete shafts w/ slip yoke CV joint?
