Pictures of ORD's 1" body lift?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by UseYourBlinker, Jun 18, 2001.
  1. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Pictures of ORD\'s 1\" body lift?
    Anybody have any pics on their rig?
    <A target="_blank" HREF=http://community.webshots.com/user/vwryda>http://community.webshots.com/user/vwryda</A>
  2. jekbrown
    May 19, 2001
    45,032
    369
    Vancouver, WA, USA
    Re: Pictures of ORD\'s 1\" body lift?
    I have the ORD 1" lift on my truck...and a digital cam. If you let me know exactly what you'd like to see in the picture...and where on the net I can upload it too (dont have a www page or anything)...I'll post some. Lemme know,
    J
  3. UseYourBlinker
    Jun 7, 2000
    11,117
    Well I am looking for pics of the following:
    Rear-I have a hitch and want to see how much gap there is
    Front-any gap?
    Side-I have nerf bars and wanted to see if there would look funny with the 1"body lift?
    Thanks for the help!
  4. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    I will second all that, I also would like to see what it looks like.
    Derf00
    http://www.derf00.coloradok5.com
    "Four wheel drive allows you to get stuck in a more inaccessible place."
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I would like to see them too.
    Tim
  6. UseYourBlinker
    Jun 7, 2000
    11,117
    Anybody?
  7. jekbrown
    May 19, 2001
    45,032
    369
    Vancouver, WA, USA
    I'll get out the digital cam tomorow...I wouldnt worry about your truck looking "funny" though, with only an inch of body lift, it doesnt really create much of a gap. You cant tell at all in the front...and in the back, it only makes a gap about half an inch or so. I can see the little aluminum blocks when I am scrubbing my rear license plate...but otherwise, never notice them. Same with the sides, not much gap.
    At any rate, for non-believers I will post some pictures tomorow...
    J
  8. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    Ok, my 75' has the ORD 1" body lift with new energy suspension body mounts. Here are some pics.
    http://www.zing.com/picture/pd2e46c040761f7cb97b79b36cc919af9/fe755834.jpg.orig.jpg
    Hard to see in this pic, but that's basically the ORD 1" puck on top of the Energy Susp. mount:
    http://www.boss.coloradok5.com
  9. UseYourBlinker
    Jun 7, 2000
    11,117
    Thanks Boss,did you have any problems with the install??
  10. Boss
    2,550
    Maryland
    no, no major install probs.
    Except, you will definately run into rusted body bolts.
    You may have to grind them off. (I had to grind off 4 body bolts)
    An impact wrench will be your best friend.
    PB Blaster or any other kind of "liquid wrench" type stuff.
    Besides all that, I don't remember any other problems.
    Boss
    89' 1 TON of FUN K5
  11. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    Hey Boss
    Nice pic of Your Blazer I take it your running a 4in lift with the body lift what i would like to know is did the kit come with the bolts And how long of a job was it? This is something that i need to do someday soon. Once again good looking Blazer.
    Ceth
    Lost? i'm not lost i'm just disorienated
  12. Ron
    Ron Registered Member
    Jun 9, 2001
    55
    Washington
    Did you have to loosen steering shaft and adjust,does this affect your clutch pedal if you have one?Any other obstacles? Do you use this kit with your factory rubber mounts? Looks great I would like to try but would like to know what I'm getting into first. Thanks Ron
  13. Boss
    2,550
    Maryland
    Highlander,
    Yes, the kit came with Grade 8 bolts for the body. But If I recalled correctly, I had to get two new bolts for the rear part (that goes through the tail pan), b/c the bolts suppled weren't long enough. No biggie there though. This is a weekend project. Let me tell you that I did this with no impact wrench or no air tools...all manual tools, except I went out and bought a grinder while I was doing this. If you have air tools, it may be quicker :).
    But, it's not hard, make sure you do one side at a time (ie, do all the driver side first, then passenger).
    Ron,
    No, no loosening on steering shaft. I have a TH350 in my 75', so I didn't have a clutch to deal with. But with only 1" body lift, you won't run into many problems as oppose to a 2" or 3" body lift.
    I did not reuse the rubber mounts when I did this. I went with the Energy Suspension Poly Body mounts. My rubber ones were all crushed and crappy anyhow. I had an article on this on my old site, but that went away. I wish I still had it b/c it explained everything in detail with pics.
    Boss
    89' 1 TON of FUN K5
  14. delta9blazer
    delta9blazer 1/2 ton status
    1,646
    Northern California, over by 7-11
    ya got any pics of your '89?
    <font color=purple>delta9blazer</font color=purple>
  15. Boss
    2,550
    Maryland
    Sure do, but no wheelin' pics yet. (Still trying to get the AGR ram right) [​IMG]
    But the 89' doesn't have energy susp or a 1" body lift. I'll PM you some pics.
    Boss
    89' 1 TON of FUN K5
