Pictures of your blazer on 44's or anything with lots of trimming
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by cybrfire, Jan 4, 2003.
  1. cybrfire
    Dec 15, 2002
    15,142
    568
    Iowa
    Pictures of your blazer on 44\'s or anything with lots of trimming
    Does anybody have pics of their mid 80's blazer on 44's running between 8 and 10 inches of lift. Curious how it looks how much fender trimming is needed. Debating between 40's and 44's. I keep thinking that if I'm going to the trouble (fun) to fit 40's I might as well put some 44's on there. Really want to stay with a max of 8 to 10 inches of lift. /forums/images/graemlins/laugh.gif How about anything with alot of fender trimming.
    Thanks SAVAGE1 for the info.
  2. rogerwilco71
    rogerwilco71 1/2 ton status
    Sep 22, 2002
    179
    Central-Cal
    Re: Pictures of your blazer on 44\'s or anything with lots of trimming
    What about 42's? Or you looking at a choice for sale?
    *bump*
  3. SAVAGE1
    SAVAGE1 1/2 ton status
    May 22, 2000
    1,104
    BAY AREA, CA
    42's and 6 inches of lift. I've cut more after this pic was taken.
  4. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    8 to 10 inches is quite a bit of lift. Are you sure you want to go that high?
    -- Mike
  5. SAVAGE1
    May 22, 2000
    1,104
    BAY AREA, CA
    Thanks a bunch. I don't know if I said it before but I am considering going to 44's with 8 inches of suspension. I have a 2 inch body lift but not sure if that counts. Mine is an 85 sitting on a 76 frame. had to do the body lift to clear the frame. Thanks again.
    cybrfire
    With that much lift you should have no problem fitting 44's, if you don't mind a little Sawsall action of course /forums/images/graemlins/wink.gif
  6. cybrfire
    Dec 15, 2002
    15,142
    568
    Iowa
    I would really like to stay at a maximum of 8". Sawzall action doesn't bother me at all. Fact I kinda like the cut look. With 8" I can retain some of the fenders though. I am kinda curious if and how you guys are retaining your innerfender well when you cut alot.
  7. cybrfire
    Dec 15, 2002
    15,142
    568
    Iowa
    I don't see too many 42's around anymore. I really like the boggers also. There is that itch again. If I had 42 why didn't i just get 44's...hmmmm /forums/images/graemlins/thumb.gif
  8. SAVAGE1
    May 22, 2000
    1,104
    BAY AREA, CA
    What inner fender well? /forums/images/graemlins/grin.gif I took mine out, but you can still get away with keeping it and cutting a lot as long as you don't cut the top edge of the fender. There are 3 bolts(i think) that run along the top of the fender that hold the inner fender in place. You can cut all you want along the fire wall.
    The easiest way to do it is remove your inner fenders, cut your outer fenders, cut a little of the inner fenders along the fire wall part, then re-install them. This saves you the trouble of cutting through two layers of fenders, which ain't always easy when the angles get awkward.
  9. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    [image]http://coloradok5.com/photos/showphoto.php?photo=361&amp;papass=&amp;sort=1[/image]
    [image]http://coloradok5.com/photos/showphoto.php?photo=362&amp;papass=&amp;sort=1[/image]
  10. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I got 40's to work with a 6" lift, 3" body and moving the axle forward 1.5". I run extended shocks and even all flexed out, it clears, I also cut the back of the fenders but I still run the inner fender. Figure I could run 44's in the mud.
  11. cybrfire
    Dec 15, 2002
    15,142
    568
    Iowa
    I was planning to cut the innerfender well and then do a little sheetmetal work and patch it in to fill the void. If i ever get that far I will take some photos...
  12. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    i've got the opposite. 13" of lift and 39's that measure to about 37. . . . but they'll be 44s soon. [​IMG]
    just thought i'd give you and idea to see if maybe you like the other look, i don't really, but that's why i'm changing!! /forums/images/graemlins/grin.gif
    (yes, you've probably seen it before i used to be here under a different name, but i forgot it!)
  13. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    here is 7"s of lift with 40" tires. click my sig if you want to see better pics. /forums/images/graemlins/ears.gif
  14. cybrfire
    Dec 15, 2002
    15,142
    568
    Iowa
    Very nice. /forums/images/graemlins/thumb.gif I can't wait to get that far. It's a progressive thing right?! So much to do so little dough... Thanks everybody for the input. Love them tires... /forums/images/graemlins/thumb.gif
  15. Re: Pictures of your blazer on 44\'s or anything with lots of trimming
    sharp looking 78, I got a 78 Jimmy thats blue wher your red is !!! Get some TSL's on there !!!
  16. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    i love Rod's rig.
    I can't wait to move up to 31's. My 28's make me feel small around these parts...
  17. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    what are the actual sizes on those tires. They look NARROW! I like the way they tuck under...sharp rig!
  18. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    38's and a 4" lift with lots of room to spare.
  19. cybrfire
    Dec 15, 2002
    15,142
    568
    Iowa
    I agree Rod's truck is awesome. I like Sapper's quite well too. BowtieRed, Very nice. Do you take that off road. Looks pretty clean. I'm not so sure I could beat the hell out of that thing. /forums/images/graemlins/thumb.gif
  20. cybrfire
    Dec 15, 2002
    15,142
    568
    Iowa
    yunit, very nice. I'd love to see some half doors on that thing... Cool... /forums/images/graemlins/thumb.gif
