Pilot Bushing & Numbers Question
Discussion in 'The Garage' started by stus84, Mar 17, 2006.
  1. stus84
    stus84 1/2 ton status
    Mar 21, 2005
    109
    MN
    I have done a search and i know a couple options - just wondering what the best option is for removing the pilot bushing. Also I was wondering if those numbers on the block mean anything? Side note I finaly got a bellhousing off Ebay $121 total and a new Luk clutch kit/flywheel resurfaced $269. I have never put in a clutch any tips would be helpful..I know I know i need to replace a few gaskets starting with the pan.
    84k5/350/465/208/Rust:doah:
  2. stus84
    Mar 21, 2005
    109
    MN
    options
    Options I have heard of:
    Option 1 - Fill with grease, find bolt that fits snugly, slam with hammer and watch out.
    Option 2 - Chisel break and pull out.
    Option 3 - Buy an expensive puller that I havent seen.
    Where would the cast - part numbers be on this motor, I have never looked it up or looked up any motor - the only thing I know is it is believed to be a 60's camero motor.
  3. stus84
    Mar 21, 2005
    109
    MN
    I will be attempting this on Sat. any tips would be great. :bow:
  4. Brocky
    Brocky 1/2 ton status
    May 22, 2005
    1,170
    St.John's Newfoundland, Canada
  5. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    Now that sounds like fun. I'll have to try that some day.
  6. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    Wait a minute, am I crazy, or does it look like there isn't a pilot bushing there. Is this a trick question? Is it already removed?
  7. koldsimer
    koldsimer 1/2 ton status GMOTM Winner
    Jan 10, 2005
    1,480
    texas
    Sliding hammer and a pilot bearing puller. It takes like two whacks and it's out. Don't struggle with the other methods unless necessary. If you have an auto zone nearby, you can rent both for free.
  8. stus84
    Mar 21, 2005
    109
    MN
    not a trick ? the bushing is in there but it it pretty bad off I think the hole is twice the original size after my clutch and bellhousing carnage. I do have a autozone nearby I will check out that puller before I attempt anything else - thanks
  9. diesel4me
    Jul 24, 2003
    17,552
    939
    Massachussetts
    one trick...
    We took one out on a sunday when no stores were open to get the proper tools ,after the packing with grease trick didn't work ..
    (We looked like spotted owls after the grease shot out and splattered in our faces!:doah: )..because the bushing was worn egg shaped..
    My brother had the brainstorm of using a 5/8" tap to thread the I.D. of the pilot bushing,and I used a 5/8 bolt to "pull" it,by simply screwing it in until it bottomed on the crank,and out it came,slick as goose poop....:D ..but the right tools are always nice of course...:crazy:
  10. NoReGrEtS
    NoReGrEtS 1/2 ton status
    Nov 7, 2005
    848
    Moreno Valley,SO CAL
    I just did this a month ago get a grade 8 5/8 bolt 5in long tap it into the
    bushing and start to tread it in it will thread all the way and pull its self out
    very easy! try it you will say the same thing:D
  11. NoReGrEtS
    Nov 7, 2005
    848
    same thing I did worked great didnt it
  12. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    Would suck if there was a bearing in there instead of a bushing.
  13. NoReGrEtS
    Nov 7, 2005
    848
    I belive they only put brass bushings in
  14. RustyParts
    RustyParts 1/2 ton status
    May 26, 2005
    235
    Wyman, Kentucky
    I'll bet the input shaft bearings on the tranny took a hell of a beating.
  15. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    Well if "they" is the factory, then I believe you are correct. You can buy bearings to install, so having to remove one would be a possibility if you ran across that.
  16. diesel4me
    Jul 24, 2003
    17,552
    939
    Massachussetts
    Whoof!..
    A cutting torch makes a sparkler out of those needle type pilot bearings without harming the crank a bit...:D ..just cut a slot in them,and dig the shell out with a screwdriver...they burn a lot faster than the crank..
    I saw one mechanic use a valve cover bolt "load spreader" thing and a bolt and flat washer,and a socket, to pull out a needle bearing one too..he filed it down just enough so it would just fit inside the crank behind the bushing,and tightened it against the washer and socket..worked well,but only once!..:crazy:
  17. stus84
    Mar 21, 2005
    109
    MN
    How do I tell if they need to be replaced - I figured if it still spins fine it is good to go.
