Pilot Bushing Question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Hoover87, Jun 17, 2002.
  1. Hoover87
    Hoover87 Registered Member
    Nov 7, 2001
    43
    Well I after looking at opinions as to which is better, a bushing or bearing, I've decided to default to using the bushing.
    Now, with the pilot bushing, is there any pre-installation tips or tricks like letting it soak in oil over night?.....or is it just a stick it in and go deal?
    Thanks,
    Mike
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I would guess that you are talking about the bushing that goes into the crank to align the input shaft on a manual transmission? If so, You should be able to just tape it in with a hammer. Use a socket to line it up (between the hammer and the bushing).
  3. Hoover87
    Nov 7, 2001
    43
    Yep, that is the bushing I am talking about. Do I need to lube at all before everything goes together, or just install it as is and be done with it?
  4. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    How deep is this bushing supposed to install? I am in the process of converting to a manual tranny and I used an old 465 tranny input shft to line it up and tap it in and I was only able to get it about 2/3 of the way in when I tapped the input shaft with a rubber mallet...Does it have to install so it is flush with the face of the hole it installs in?
    Chris
  5. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    I did this once on a furd. Make sure the bearing/bushing isnt in a bind. I got it a little sideways and it wouldnt budge. The one I installed went flush. Also, I would use a socket that is the same size as the outer race, you could screw it up by beating on the inner race.
    Try to PM KRAZIE87K5, he just finished this swap and could probably give you a good idea of what to do.
  6. SWAMPRNR
    SWAMPRNR 1/2 ton status
    Apr 7, 2001
    296
    Temple Texas
    Mine sits flush after it was tapped in place.
