Pinion angle for 14FF in a K5?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BillyBob, Feb 19, 2002.
  1. BillyBob
    BillyBob 1/2 ton status
    Feb 23, 2000
    557
    Dumont, NJ
    Well, I got myself a 3/4 ton drivetrain. After I paint it and get some tires, it's going in under my stock K-5. Now, I heard that, since these diffs were inteanded for longer wheelbase trucks, my pinion angle is gonna be all screwed? is there any way I can make this work without needing a lift? anyone got any advice I can use? I wanna get this diff under the truck and working fine in a weekend, since the truck is my daily driver, and it sounds like my 10 bolt is about to blow up. Help.....
    <a target="_blank" href=http://billybob87k5.50megs.com>Homepage of Porky & Stinky</a>
    ".. Sanatarium.. leave me be..."
  2. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    If its from a 3/4 truck its should be damn close to your current pinion angle. Should be a direct bolt in.
    Its the popping, rumbling, roaring, twisting, flexing, grinding, so you can wheel anywhere medicine[​IMG]
  3. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    Here's the deal. What you want to achieve is keeping the centerline of the output shaft of the trans case and the centerline of the pinion gear parallel to each other and at the same time having no more than 3 degrees working angle on both u joints. This is very hard to do on a short wheelbase vehicle, but you said your blazer is stock now. You should be able to achieve this easily. Goodluck
  4. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    On mine with a stock suspension I had to drop the t-case.
    When I nailed the gas the rear yokes would bind and make an ass puckering noise.
    I am not sure if this is due to using a 2x4 rear axle or what.
    I dropped the case 1.5 inches and all is well.
    <font color=green> Too bad ignorance isn't painful </font color=green>
