pinion angle with flip?
Discussion in 'OffRoad Design' started by TX Mudder, Jan 27, 2001.
  1. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Do you have any experience with what the pinion angles are like when yo do the 4" shackle slip on a LWB truck?
    I read the FAQ on the website and it says that it pretty close to ideal for a k5 or swb truck. But think I read about someone with a LWB having the pinion angle about 15 degrees off and not being able to find a big enough shim.
    I really don;t want to lower the tcase because that would make the front angle on my 205 even worse - it's bad enough with a 6" lift as is. :)
    -- Mike 73 k20
  2. Stephen
    Sep 15, 2000
    4,228
    142
    Carbondale Colorado
    It really depends on what brand of block you compare it with, but we have measured about 3 degrees more pinion up on a truck where we swapped out a block and went to the flip. One customer milled his own rear block to work with a 6" front spring and put about an 8 degree angle on it. in a LWB truck with a 465 and 208.
    What we usually advise it to put it together and measure the angles, then look at how to fix it. a shim should do the trick for you, if you don't want to run one, you could rotate the perches on the axle housing. We had to move the perches on my k5 when we went from a stock spring to a custom spring. That was the only change but it was over 10 degrees we had to rotate the perches.
    Hope this helps, it's not very specific because it's hard to be specific due to some of the variables
    Maybe some LWB customers will see this and pipe up on how their kits worked out?
    Making the world better, one truck at a time.
    SW-ORD
  3. Russ1020
    Russ1020 Registered Member
    Jan 20, 2001
    37
    Gulf Coast Texas
    I helped a guy put a one ton ford alxle under a bronco 2 before and we got his angles great by cuting the spring perches and welding them where he wanted them. It worked great and he never had any problems out of it.
    Russ77k10
  4. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    With all the talk about pinion angles with shackle flips (look how many posts on the regular 4x4 board have been made about this over the past few months) doesn't it seem the "easiest" (didn't say least costly [​IMG]) way would be to go CV driveshaft? Might be wrong, please educate me if I am.
    <font color=orange>'79 - 406 TPI -<font color=orange> K5#5 - <font color=blue>See it at---&gt;<A target="_blank" HREF=http://www.blazzinor.coloradok5.com>http://www.blazzinor.coloradok5.com</A>
  5. Stephen
    Sep 15, 2000
    4,228
    142
    Carbondale Colorado
    With a K5 you probably are better off going with a CV joint and being done with it. I fought pinion angle on mine for a couple of years and finally bit the bullet, went with the cv joint and never looked back. Most K5's end up with a little too much angularity to work smoothly at highway speeds. Now there are a lot out there that work, but, there are some specific circumstances to help, like low lift, short t-case, high axle gears, tall tires, etc.
    For most late model guys with an overdrive, running deep axle gears (like 4.56) and any kind of lift, the cv will probably be cheaper in the long run.
    thanks
    SW-ORD
