pinion angle
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MA87K5, Apr 6, 2004.
  1. MA87K5
    MA87K5 1/2 ton status
    Apr 6, 2000
    558
    Chicopee, Ma 01020
    I did the search but couldn't find the post I was looking for. What is the max for degrees between the pinion ant the x-fer case with a straight driveshaft? Thanks
  2. rcpilot
    rcpilot 1/2 ton status
    Feb 22, 2002
    507
    Central Cali
    I seem to recall 15 deg... /forums/images/graemlins/dunno.gif I'm sure someone will have the correct answer here
  3. MA87K5
    Apr 6, 2000
    558
    Chicopee, Ma 01020
    I read smoewhere about 3* difference. Maybe I read wrong.
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    This should help, first thing I ever read when I looked into possibilities :
    Driveshaft 101
  5. MA87K5
    Apr 6, 2000
    558
    Chicopee, Ma 01020
    Thanks, but I'm actually looking for the max difference between the x-fer and the pinion. example: pinion 10*, x-fer 13*, difference of 3* I'm not looking for driveshaft angle. Thanks for the help so far.
  6. rcpilot
    Feb 22, 2002
    507
    Central Cali
    You are correct max diff is supposed mo more than 3*...in my previous post I thought you were referring to total deg's
  7. MA87K5
    Apr 6, 2000
    558
    Chicopee, Ma 01020
    Thank you very much. Now I can get a new driveshaft.
  8. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,073
    486
    Grand Rapids area
    3* difference will live, but vibrate. Shoot for 0-1. Really.
    The exception is with a CV driveshaft.
  9. MA87K5
    Apr 6, 2000
    558
    Chicopee, Ma 01020
    at 3* now it barely vibrates. doesn't the pinion have to point at the x-fer for a cv shaft?
  10. rcpilot
    Feb 22, 2002
    507
    Central Cali
    The pinion should point slightly down from the direct line to the transfer case. That should yield no vibrations...
