pinion angle
Discussion in 'The Garage' started by sf_wood, Jun 3, 2005.
  1. sf_wood
    sf_wood Registered Member
    Apr 4, 2005
    san francisco ,ca
    So i bolted my front end altogether(d44 8lug,6"tc springs,ORD hd shackles,greasable bushings,X-over, ford shock mounts,new balljoints,TRE's) my pinion angle was 4* measured from pinion,T-case was 6* measured at pinion (cv style). axle on jack stands,truck level.
    Couldn't measure driveshaft, wouldn't flex enough started to bind.
    1977 k10 350/465/205/d44/14bff
    Rear -2" tc springs ORD 4" shackle flip
    Bilstein 5125 14" travel shocks all around
