pinion angle
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Mudologist, Jun 10, 2001.
  1. Mudologist
    Mudologist Registered Member
    May 9, 2001
    57
    Hazleton, Pa 18201
    I have heard talks about shops cutting the knuckles off front axles and rotatioing the pinion angle up and then rewelding the
    knuckles back on, or spinning the axle tubes to rotate the pinion angle up. Has anyone heard about this or had this done???
    Also is the dana 60 pinion angle any higher than a dana 44 pinion angle? And how much higher is a reverse rotation dana 60
    compared to a standard rotation dana 60?
  2. tRustyK5
    Jul 23, 2000
    36,170
    1,379
    E-town baby!
    Cutting and rotating a front is usually reserved for the large lifts. Its not an easy job and usually costs a fair chunk of change to have it done. The problem is that if you try to improve your pinion angle for the driveshaft you are changing your caster angle and the truck will be all squirrelly on the road. Thats the reason behind cutting and rotating.
    I'm not sure if the D60 pinion is normally higher than the 44 or 10 bolt. The high pinion D60 is quite a bit higher than the regular one...but is not available as a passenger side pumpkin. You could run a Ford D60 HP front with some work and a Ford T-case though.
    Rene
  3. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    i had my front 60 done
    you have to remember the cast spring perch has to be rebuilt to the new level, and then the hard part is the studs for the spring plate no longer point up.
  4. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    You can do it that way, but if you are going to go through that much trouble, some shops actually unweld/press out the axle tubes, rotate them and repress/reweld them. That keeps you from having to cut and reweld the knuckles and spring perches which MAY lead to weaknesses. This is the best approach for a D44 or 10 bolt since they use 4 u-bolts (unlike the D60 which has 3 and 2 bolts/studs). It does require a little bit-o-grindin on the pumpkin to make the oddball (i.e. longer and wider) u-bolt to fit properly on the rotated pumpkin.
    If you didn't built it yourself, how can you call it yours.......?
