PINION ANGLE?????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MITCH89', May 5, 2000.
  1. MITCH89'
    MITCH89' Newbie
    FL
    I HAVE A 3" TUFF COUNTRY SUSPENSION ON MY 89. THE KIT CAME WITH TAPERED BLOCKS AND ALL, BUT I STILL EXPERIENCED VIBES.I LOWERED THE T-CASE AND THAT HELPED, BUT ITS STILL THERE. SOMEONE TOLD ME TO BUY 3 DEGREE SHIMS. WILL THAT HELP? WHERE DO I GET THEM? AND IS IT OK TO STACK THEM WITH THE BLOCKS THAT ARE ALREADY THERE?THANKS............
  2. titanic
    titanic 1/2 ton status
    Mar 27, 2000
    498
    north alabama(huntsville)
    I would not use shims and a block together. What about a cv type driveshaft? They usually help !
  3. 88Jimmy
    88Jimmy 1/2 ton status
    100
    Las vegas, NV
    Mitch
    Did you put in NEW U-joints
    Your driveshaft could be out of phase try turning it 180*
    If you removed you driveshaft did you mark the position it was in the slip yoke?
    you could try moving it 45* and trying it again!
    350 Vortec TPI D60 14Bolt 4.56 4"lift 35 BFG A/T
