Pinion Angle ????
Discussion in 'The Garage' started by blazindorito, Sep 11, 2006.
  1. blazindorito
    blazindorito 1/2 ton status
    Nov 25, 2003
    2,047
    Southern California
    What should the pinion angle be on a 14bolt ff? I have an 83 k5 with a 400/205, 6" lift springs both front and rear. The rear springs came with a 6* shim but driveshaft is binding or hitting the u-joint. I measured and came up with 9* up. After axle wrap I should move it up 6-7*. Does this seem right? Just want to make sure before. Thanks.
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    The angles are determined by measuring. There is no exact # that fits all K5's/Trucks's
