pinion angle
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by gmcjimmy4x4, Nov 12, 2006.
  1. gmcjimmy4x4
    gmcjimmy4x4 1/2 ton status
    May 6, 2005
    132
    Sacramento, CA
    anyone know approximately what size angle shim i should be using. Ive got 91 jimmy with a 14 bolt, 6" lift and a sye kit with a cv driveline
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    I have an angle finder, if you want I will lend it to you and teach you how to measure it or if you can drive it now, come to me and I will measure it for you.
    No one can guess the angle too many parameters.
    PM me if interested.
  3. ssped
    ssped 1/2 ton status GMOTM Winner
    Jan 5, 2006
    1,529
    Mission Viejo
    is the rear lift a shacle flip? I am running 6deg.
  4. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    It depends on the shape of his springs, what brand, I have put anything from 2 deg to 10 degree shim all on 4" lift K5's.
    Don't guess when you can know.
    :D
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I got about 5.5 inches from my Echobit shackle flip and stock 52's , I do not run shims .
    Regardless how the lift was done , a good rule of thumb with a CV is to have the rear pinion point right at the transfercase .
  6. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    I tip my pinion about 2* down from center to allow for the little upward axle wrap that happens upon normal driving conditions which will then point it to the centerline of the T-case output shaft when driving.
  7. bp71k5
    bp71k5 3/4 ton status Premium Member
    Mar 31, 2006
    6,239
    284
    San Jose, California
    When I installed my ORD shackle flip and 2" springs, the pinion angle is just about perfect for the CV joint. You might not need any shims at all.
  8. gmcjimmy4x4
    May 6, 2005
    132
    Sacramento, CA
    im sure i need shims, just not sure if im reading the angles properly. From the measeurements i took with an angle finder it seems like it needs about 14 degrees. and thats with the shim that comes with the spring.(4* i think)
  9. ssped
    Jan 5, 2006
    1,529
    Mission Viejo
    Post up pix and let us look at her. Basically point the pinion a small bit down from directly pointing at the tcase output.
  10. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    To give you an idea, i'm doing some rear axle work myself right now and i just measuered my pinion angle tonight. With the truck on flat ground and my angle finder on the driveshaft i have 17.5*, i then pulled my driveshaft and put the angle finder on the rear axle pinion yoke and it also was at 17.5*. The pinion yoke and the driveshaft angles should be the same or the pinion pointed down 2* if you're running a CV rear shaft. The angle will be different for every vehicle though depending on the size of your lift and also the tranny t-case combo you have.
  11. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    im using the shims that came with my 5" lift 64's, i believe they are 5* with a shcakle flip and my angle is perfect for a cv, but im not running a cv yet
  12. gmcjimmy4x4
    May 6, 2005
    132
    Sacramento, CA
    how much angle shims are you running?
  13. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Well, i am running a 4" superlift spring with an ORD 4" shackle flip then i moved the axle back 1.5" with a 4* tapered offset zero rate that is an extra 3/4" thick so that i could remove the factory overlaod from the spring pack without affecting ride height. Currently i am removing my tapered zero rate and cutting the spring perches off and made new perches that will get welded back on so that i won't need any tapered shims and this is all using new superlift springs and keeping the overloads installed this time. The springs will be installed backwards so the axle will move back 1" and then my perches have a 1" offset hole as well so i'll end up with my axle 2" rearward.
  14. lunchbox
    lunchbox 1/2 ton status
    Jan 22, 2006
    309
    novato,california
    where can you buy shims at?
  15. gmcjimmy4x4
    May 6, 2005
    132
    Sacramento, CA
    I just orderd mine from jkwoffroad.com. I havnt recieved them yet,but hopoe to any day now. Not many places make custom angle shims.
  16. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    Rubicon express, local in Rancho Cordova. I got a few sets from them $35 a set
