pinion angle
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by CAROLINAK5, Nov 16, 2001.
  1. CAROLINAK5
    CAROLINAK5 1/2 ton status
    Aug 2, 2001
    242
    lexington, north carolina
    how can i find this? do i need any special tools? all i have to work with are the basics.....a big hammer and lots of band-aids.[​IMG]
    when all else fails..............HIDE!!!!!!!!!!!!!!!!![​IMG]
  2. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    You need to get an angle finder from Snap on or Harbor freight.
    Surgeon General's Warning:
    Viagra and steroids may be harmful to your spouse![​IMG]
    <a target="_blank" href=http://www.nashvillek5.freeservers.com>www.nashvillek5.freeservers.com</a>
  3. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Just about any magnetic angle finder will work. If it doesn't fit the u-jont cap, use a spacer (like a socket that will fit inside the yoke rim, and contact the cap.)
    Try to set the pinion angle down by 1 or 2 deg. vs. the t-case out-put angle. Because, when the axle is loaded, it will rotate slighly and bring the angles back into alignment.
    <font color=blue>Twiz</font color=blue>
