? pinion angle ?
Discussion in 'The Garage' started by purple76pearl, Jan 15, 2003.
  1. purple76pearl
    purple76pearl 1/2 ton status
    Jan 13, 2003
    450
    missouri
    what is the best way to fix front pinion angle with an 8 inch lift on my 75 chevy 3/4 ton, and any good cures out tehre for steering? i want flex even if i dotn use it, i want to have it /forums/images/graemlins/k5.gif /forums/images/graemlins/ears.gif
  2. jeffro
    jeffro 1/2 ton status
    Jul 2, 2002
    406
    Scurry, TX
    The "best" way might be cutting and rotating the axle housing. Using too many shims is hell on your caster. Better yet, budget a crawler in there and gain 6 inches. This will reduce the driveline angle required. It will shorten the rear but rears are more forgiving anglewise.
    Jeff
  3. 72THING
    72THING 1/2 ton status
    Nov 26, 2001
    501
    Ranburne, AL
    I have 6" lift springs on my '72 and I just have a set of 6* shims in the front. I also have the front spring hangers dropped an inch to help point the pinion up a little and combined with the taller D60 spring perches and 6" springs, it equals about 8" of overall lift. As far as steering correction goes, I have to say crossover steering is the way to go. It is pretty expensive, but after having it I would never go back with regular front-to-back steering. My truck turns SO much sharper with crossover than it did before.
    Will
  4. purple76pearl
    Jan 13, 2003
    450
    missouri
    if i cut and rotate my axle housing, what do i do about the u-bolt on the front will it still work the same, or whats the cure for that? /forums/images/graemlins/k5.gif
  5. jeffro
    Jul 2, 2002
    406
    Scurry, TX
    You could still run shims and it wouldn't matter because the caster has been corrected.
