pinion angles, what gives
Discussion in 'The Garage' started by jjlaughner, Apr 10, 2003.
  1. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    OK this is a two parter
    1st I have an 87 K5 stock 10bolts and for the last few years I have to replace the rear universal about every 9 months. I just replaced it in Dec and its clunking real hard again. How can I measure the angle I have and would I benifit from dropping the transfercase a little?
    Part 2
    I also have an 87 blazer that I'm getting ready to put a 3/4ton 14BFF into. I know the spring perches are right BUT, if I where to use a 5" rear spring or any combo of shackle flips, Would I benifit from rotating that springs perches (Fabing new ones, like Greg72 's) with the built in relocation? (the question here is the rotation of the perches, not the different perchs). Otherwise, I will be sandwiching a shim, zerorate, and spring -instead of the spring to new perch. (I'm also thinking about the angled zerorate, I see at the ad on top for a-tron I think it was).
    ---I just found this at a-trons website
  2. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    If it's the stock setup (i.e. suspension, axle, height, whatever), then the problem has to be in the joints you are using. Are you getting greasable or non? Or are you greasing them frequently enough?
  3. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    The new joint is a brute force, non-greasable (NOT MY CHOICE, but it was all that was avaliable when I needed it done to get to work). the others where Timken greasable and they got shot with oil changes. This new bruteforce is less than 3000 miles /forums/images/graemlins/angryfire.gif
    added...
    Yep, stock heigth springs, gears, everything except the auburn limited I put in a while back when I ate up a couple gov-locs in the mud.
    What are the part numbers for stock spicer u-joints? Maybe I can get them ordered. To bad CMT does not have a u-joint for this I would drop $100 on one if I didn't have to deal with it or worry about being a POS!
