pinion angles
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by hd-10, Feb 20, 2005.
  1. hd-10
    hd-10 1/2 ton status
    Jan 31, 2004
    188
    lemoore, ca
    can i use wedges with 4" blocks? were's the best place to get them if i can? also got 1" zero rates, would the wedge go between the block and axle or block and spring
  2. sickquad
    sickquad 1/2 ton status
    Jul 23, 2003
    785
    Ma
    Blocks suck. I have always put my wedges on the axle perch first. Call ORD they can give you everything you need and also answer your questions based on what you are buying.
