Pinion Angles..
Discussion in 'The Garage' started by 82K5_6.5L, Mar 6, 2005.
  1. 82K5_6.5L
    82K5_6.5L 1/2 ton status
    Dec 4, 2002
    439
    Tucson, Az
    so i was cheap and had some 3.5" blocks in the rear, and due to the angle i had to lower the t-case about an inch. now i did a shackle flip,and put my 12 bolt on, and the pinion angle is much better! do u think i should take the t-case spacers out, or leave them?? before the spacers, it would vibrate like a mofo.. :( any info appreciated..
    gotta go bleed the brakes.. :D fun stuff!
  2. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    You'll have to take a look at how the driveshaft looks. It would be nice not to run the spacer on the TC, but if your angles are better with it, you should keep it on.
